- Past hour
BaXXon replied to FiveThreeFive's topic in Opinii si editoriale
Viitorul ev - byd.....- 3651 replies
- electric
- electric cars
(and 2 more)
Tagged with:
- Today
Update: am mai adaugat ceva ieri/azi.. scaune comfort/ventilatie/memorie/masaj mai am de pus fetele de usi + cablaj memorii + o curatare la interior dupa.
ELB0B0 joined the community
Eu la F30 am ca dotari 563 (Pachet Lumini) cu 552 (Faruri adaptive LED) si 5AC (Asistent faza lunga) Sunt cam 4 features distincte la nivel de far: 1. Directionarea lumii la viraj, corelată cu aprinderea proiectoarelor 2. Schimbarea modului de iluminare in functie de zona si viteza, pune lumina diferit pe asfalt in oras fata de drum national/autostrada (unde bate mai departe si mai spre acostament) 3. Decupajele de lumina in functie de masinile care vin pe acelasi sens cu tine sau pe contrasens, practic tine cealalta masina intr-un con de umbra 4. Schimbarea efectiva cu fata lunga..atunci cand din fata nu vine nicio alta masina. E cea mai putin relevanta, dupa mine, ca este utilizata rar.
- Yesterday
05A4 LED headlight with extended scopes Am chestia asta, oare ajută? Edit: AI-ul lui Google zice așa: The 05A4 code designates "LED headlights with extended functionality" for certain BMW and MINI vehicles. These aren't just standard LED headlights; they include intelligent features like automatic high beam control, city and country lights, and the ability to adapt the beam pattern to avoid blinding other drivers. In MINI vehicles, the code may also refer to customizing light signatures for the daytime running lights. Features of 05A4 LED headlights Adaptive high beam: The system uses a camera to detect other vehicles and automatically adjusts the high beam to avoid dazzling them, while still optimizing the road illumination for the driver. Intelligent light modes: Depending on the model, the headlights have specific modes for different conditions, such as city, motorway, and bad weather lights, which adjust the beam pattern accordingly. Customizable light signatures: On some MINI models, you can select different light signatures for the daytime running lights and customize the "welcome and farewell" light animations. Enhanced visibility: The system is designed to improve visibility during nighttime and poor weather driving by automatically switching between high and low beams and adapting the beam to road conditions. How to identify if your car has this feature Check your vehicle's equipment codes: Look in your owner's manual or on the sticker in your door jamb for the code 05A4. Watch your headlights: When you start your car, observe if the headlights move or adjust themselves. This is a key sign of adaptive headlights
Heziix joined the community
Exista doua opțiuni separate: S552 Adaptive LED headlight S5AC High-beam assistant S5AC asta face, aprinde faza lunga automat in functie de traficul din fata, nu are functie de adaptive. Daca chiar ai adaptive, ca înțeleg ca sunt mai multe feluri, acea functie asigura adaptarea a fasciculului luminos in functie de masinile din fata.
Laurentiu V joined the community
ADRIANO740d joined the community
Salut, Liviu. Am aceeași problemă ca și tine, de aproximativ un an, și de acum 4 săptămâni masina este în service, dar tot nu îi dau de cap. Are aceeași eroare și aceleași simptome. Este cel cu 2 turbine, 306 CP. Am schimbat toate furtunașele, am înlocuit senzorul de presiune a gazelor de la eșapament, ne-am uitat și la debitmetru… Încă nu știu ce are și deja îmi pierd răbdarea. Văd că postarea e mai veche și mi-aș dori să-mi spui, te rog, dacă ai reușit să o rezolvi și care a fost problema. Adrian Adriano sunt pe farcebook. Am o poza in tricou negru si cu ochelari la profil, incaz de vezi mesajul asta si ma poti contacta. Mulțumesc!
AndreiFM joined the community
daca se poate pune si o poza cu toata masina
MyKe started following BMW bussines cd43
Buton volum - 65126907818 Capac lateral - 65126907824 Dai codurile astea la orice magazin de piese auto, sau îi scrii lui grozadan aici pe forum. Ex:
goangaus started following High Beam Assist - functie achizitionata din BMW shop
Bimmerlink e doar pentru diagnoza, Bimmercode e pentru codari, dar atentie ca sunt cazuri de daune colaterale, eu as merge la cineva care se ocupa cu codari. Bimmerlink am si eu pentru citire erori, date live, adaptari, etc. Ai faruri adaptive? Ca altfel nu are cum sa direcționeze lumina in functie de traficul din fata.
mariusbaz joined the community
E38bmw1239 started following BMW bussines cd43
Bună ,am un casetofon credca este original ,aș avea nevoie dacă cunoașteți să îmi ziceți de unde aș putea cumpara 2 cleme pe lateralele casetofonului și de un buton de volum ,o recomandare ,un site de unde pot comanda etc…
RedCap replied to FiveThreeFive's topic in Opinii si editoriale
Dar ala tot 6.2 facea asta asa ca idee. Care făcea suta in 4.3? Mai ai BMW acum?- 3651 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Ciprian01 replied to FiveThreeFive's topic in Opinii si editoriale
Un post din 2023...de atunci masinile mele au facut 4.3 si 5.4, hatere :)))- 3651 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Poți incepe cu valve vanos si actuatori vanos. Valve poti lua Ina care sunt 200 lei bucata si sunt exact alea care vin pe Original, la 800 lei bucata si actuatori vanos Original 350 lei bucata. Totodată schimbă si capacul culbutori pe original, că mai mult ca sigur nu a fost schimbat niciodată. Si mai poti schimba si valva de ventilatie a vaporilor de benzină, care costa 160 lei pe BOSCH, care vine echipare de original , dar la prețul de 800 lei originala
@Ciprian01 nu era nici noapte, nici nu am stat să mă gândesc. Acum tu poți să o întorci cat vrei dar nu ai specificat nimic de vreo electrică sau termică, ai spus la modul general.- 3651 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Incerc resuscitare topic cu intrebare daca ai rezolvat problema. Si eu am un zdraganit foarte urat in mers constant sau decelerare. Pot sa-l reproduc si pe loc. Prima data m-am gandit si eu la wastegate, dar parca suna mai urat de atat. Ma gandesc si la actuatoarele VANOS. Nu am erori, masina merge ok, insa saptamana trecuta cand am oprit in benzinarie a avut fluctuatii la relanti, deci cred ca si alea sunt pe duca. Am si un video: idei cineva ce poate suna asa urat? https://www.youtube.com/watch?v=YL89wkOfXkY
lillejhon started following High Beam Assist - functie achizitionata din BMW shop
Sunt în situația în care mi-o doresc :)) Funcția Aștept BlackFriday, că am înțeles că se mai fac discount-uri. Mașina se comportă la fel ca a lui OP. Aș achiziționa fără sa stau pe gânduri dacă aș ști sigur că face acel con, că izolează vehiculele de pe contrasens. În rest nu mi-e silă să dau fază lungă singur, la nevoie.
Daca schimbi bateria cu una de capacitate asemanatoare: de ex ai de 92Ah si pui una de 95-96, nu trebuie codare, doar inregistrare. Daca pui una de 105Ah, atunci trebuie codare. Dar, da, daca mergi undeva unde cu asta se ocupa, stiu ei tot ce trebuie.
Ce te-ai gandit tu intr-o noapte la istoria mea bmw-istica, sa faci in asa fel in cat sa imi dai peste nasuc Nu compari niciodata termic cu electric, sa faci un 0-100 rapid la electric e peanuts, rapid, tzap, tzarap.- 3651 replies
- electric
- electric cars
(and 2 more)
Tagged with:
alex230ro replied to FiveThreeFive's topic in Opinii si editoriale
se aglomereaza treaba in zona de 40k eur- 3651 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Announcements
Topics
