- Past hour
BMW F36 2016 probleme Egr
RedCap replied to Alex1996044's topic in Probleme tehnice si rezolvari Seria 4
@Alex1996044 eu vad ca asta am intrebat. - Today
g01 X3 G01 30i zgomot la descuiere
ADRIAN HD replied to goangaus's topic in Probleme tehnice si rezolvari Seria X
La far se poate ajusta acel luft dar trebuie demontată bara.Din poze nici garnitura dintre aripă și far nu stă cum trebuie,pare cobarâtă in jos,nu trebuia să fie până la capătul aripii? -
Ceva de genul se aude. Oricum e slăbuț față de cum se aude E92 . Eu fiind obișnuit cu zgomotul, mi se pare că asta se aude incet tare . VID-20250604-WA0006.mp4
Vroom joined the community
Maddanny28 joined the community
The BMW M340i typically consumes around 8.5 liters per 100 kilometers combined (WLTP) with CO2 emissions of 192 g/km. However, real-world fuel consumption can vary significantly based on driving conditions and style. Some drivers report achieving around 25-27 mpg on highways, while others report lower figures in city driving or when driving spiritedly. Here's a more detailed breakdown: WLTP Combined: 8.5 l/100km (approximately 27.7 mpg US). WLTP CO2 Emissions: 192 g/km. City Driving: Expect lower fuel economy in city driving, with figures potentially ranging from 10.3 l/100km (22.8 mpg US) to 13 l/100km (18.1 mpg US), depending on traffic and driving style. Highway Driving: Highway fuel consumption can be more favorable, with some drivers reporting 25-27 mpg (around 9.4-8.7 l/100km). Spirited Driving: When driven aggressively, the M340i's fuel consumption can increase significantly, with some users reporting figures around 15.5 l/100km (15.2 mpg US) or higher. Real-world variations: Factors like driving style (aggressive vs. economical), tire choice, weather conditions, and road types can all affect real-world fuel consumption. Intr-o dilema similara am fost si cand am cautat X3, sa fie M40d sau M40i, iar avand in vedere ca in ultimii 2 ani am facut 100k km, am simtit putin la buzunar d-ul... realitatea e cam aia, intre 3 si 4L% in plus medie reala, in mod special la mers la alert/sportiv, acolo se simte si mai tare diferenta de consum. La mers frumos/lejer/consum, diferentele nu sunt chiar asa mari poate undeva la 1-1,5L%.
Salut. Comparatia era strict intre 340i si 340d. Lar 340d consumul e similar cu 320d, poti sa il abuzezi cat de tare vrei (inculsiv accelerari 100-170), nu o sa treaca de 8-9 consumul la drum lung. Eram doar curios unde e consumul la 340i in acelasi stil de condus. Merg undeva la 25k km pe an, destul de mult in afara, dar ca timp, merg foarte mult si in Bucuresti. 4% la media de consum se simt la 25k, dar nici diesel mare in oras nu e indicat, de aici dilema mea.
Alex1996044 replied to Alex1996044's topic in Probleme tehnice si rezolvari Seria 4
Cum adică nu se poate schimba nimic ? -
goangaus replied to goangaus's topic in Probleme tehnice si rezolvari Seria X
Probabil o sa o las asa, nu stiu daca afecteaza cumva farul ca o sa intre mai multa apa pe acolo, mai ales la mers pe ploaie. Nu îmi dau seama cum de nu am observat cand s-a inlocuit farul, chiar am verificat daca totul este in regula este posibil sa se fi deplasat in timp? Dar nu prea vad cum sa se ridice farul, ca bara e bine pusa la locul ei. -
Nah,Tik Tok sa vezi ce frumos e cand se intind pe capota :))
Cosminbad started following BMW F32 430i
Frumoasa masina. Cum se aude toba? Are valva si se aude mai tare in Sport sau Sport plus? (eu am PF la benzina si e cam muta pe confort, doar in ture mai intalte + sport se aude sau la pornirea la rece cateva secunde, cand se aude chiar fain) Probabil tinerii vand vreun cazan pe OLX si folosesc pozele lui - E tipla frate! Full !
sskkaa started following X3 G01 30i zgomot la descuiere
sskkaa replied to goangaus's topic in Probleme tehnice si rezolvari Seria X
Si a mea are un mic gap acolo intre far si bara, de fabrica, poate nu asa pronuntat ca la tine dar tot se vede putin. Eu zis sa nu ti bati capul inutil. Bucura-te de masina. -
DragosPena replied to Alex1996044's topic in Probleme tehnice si rezolvari Seria 4
Pai in primul rand un cod de eroare ar ajuta, dar cu ISTA nu coduri generice cu multimarca. -
boaba started following Turometru instabil și vibrații G30
Resetare adaptari, update de ilevel mai ales daca ai schimbat actuatorii.
Barbu Dănuț started following tita alexandru adrian
Barbu Dănuț joined the community
In continuare masina prezinta simptomele, nu s-au agravat nici indreptat...e acolo. - bujii noi - bobine noi - actuatori vanos noi - tank valve breather nou
Sunt in Begia acum și oare ajuta o curățare la raci forul de gaze ? -
Am reusit sa fac retrofitul la acc simplu momentan, functioneaza corect. Din cauza optiunii S5ASDriving Assistant nu am putut sa il trec in VO, aceasta ma forta sa adaug si cele 2 radare din bara fata (le am doar pe cele din bara spate pe masina). Are cineva o idee cum bypassez cerinta? Ca sa il trec in VO
- 22 replies
v@sy replied to goangaus's topic in Probleme tehnice si rezolvari Seria X
Din poza pare ca farul nu e aliniat cu restul elementelor. Farul are suruburile de prindere de unde se poate modifica pozitia lui. Dupa realinierea farului trebuie verificat fasciculul luminos, pt ca isi va schimba pozitia. -
Mai mult de 1 an nu o mai țin, oricum asta era planul de la început. Majoritatea nemulțumirilor mele sunt cauzate de reprezentanta, masina ar trebui sa se repare, orice problema ar apărea. Dar se pare ca e mai greu sa găsești oameni serioși. -
Ciprian01 replied to goangaus's topic in Probleme tehnice si rezolvari Seria X
Eu zic sa o vinzi, la fiecare 2 zile ai o problema cu ea, e clar ca nu e ce trebuie... -
Dar oare se poate alinia corect, exista reglaj la prinderile farului? Ca bara e aliniata bine cu aripa, nu vad ce s-ar putea modifica, doar poziția farului. Mai mare bataia de cap, bănuiesc ca trebuie apoi si reglate farurile, oare este vreo problema dacă o las asa, risc sa pățească farul ceva? Bănuiesc ca intra mai multa apa pe acolo, dar oricum nu era water sealed, ajuta si la ventilatie... Doar ca deranjeaza la ochi. O sa dau un email si la BMW, sa le mulțumesc pentru serviciile ireproșabile. -
alex230ro replied to goangaus's topic in Probleme tehnice si rezolvari Seria X
Dupa 6 luni nu mai ai ce sa le ceri, cam asa au facut si ma mine la 140 cand au schimbat aripa , am mers inapoi s-au uitat a zis ca da e un pic de tot luft dar asa e si ca ei nu prea au ce face. Oricum deja vroiam sa vand masina asa ca nu mi-am mai batut capul cu ei. Pana la urma la culoare a iesit perfect asa ca am zis macar atat , la partea de aliniere elemente cand am inceput sa ma uit cu atentie nimic nu era "ca de fabrica" dar asta e riscul cand se dau jos elementele de pe masina pentru a fi revopsite . AB Otopeni a fost la mine . LE: luftul arata ca si la fostul meu X1 dupa ce bara a fost data jos de vreo 2 ori -
Am observat zilele trecute ca la farul inlocuit pe garantie am un spațiu destul de mare intre far si bara, sa fie cam 5mm, mi-a sarit in ochi pentru ca dintr-un anumit unghi se vede ce e sub bara. Si la farul celalalt este un spațiu acolo dar nu asa de mare. Cum vi se pare, e normal sa fie spațiul ala asa mare acolo? Bara pare bine fixata, nu stiu farul daca are ceva reglaje de poziție. Lucrarea a fost făcută la faimoasa reprezentata Baneasa. M-am mai uitat pe strada la diverse BMWuri dar nu am observat acel spațiu asa vizibil. Nici cand am ridicat masina nu am observat, au trecut vreo 6 luni de atunci. -
spune ce eroare ai, eu unul am postare ca schimb la ele in draci, un racitor la 10 luni :)) sa faca procedura din ISTA sa vada daca e problema la racitor sau la EGR, daca a fost schimbat OEM EGR ul nu crapa intr-un an si tind sa cred ca e racitorul. de unde esti ? -
SUPERBA! S-o alergi cu placere
Sincer, nu stiu exact . Cică au filmat-o si pozat-o din toate unghiurile . Cine știe ce videouri de oscar vor sa faca.
Topics
