Dan_316i
Everything posted by Dan_316i
  1. ok fct de o sapt, dar cat e tura, ca nu am gasit nimic pe siteul lor
  2. pachetul de drumuri grele, masina e mai inalta din pricina tampoanelor de cauciuc care se pun la arcuri, pe spate sunt de 4 dimensiuni 5mm, 7.5mm(asta e std), 10mm, 21.5mm
  3. 31 00 Front axle - ride height E36 since 92 Mod. Ride level in normal position (attach tape measure to rim flange at bottom middle and measure to lower edge of wheel arch) Deviation from nominal value for all wheels together Max. mm 10 Series "15"" rim" 576mm "16"" rim" 589mm "17"" rim" 604mm Low-slung sports suspension "15"" rim" 561mm "16"" rim" 574mm "17"" rim" 589mm Rough road package "15"" rim" 596mm "16"" rim" 609mm "17"" rim" 624mm Issue status (12/2007) 33 00 Rear axle - ride height E36 since 92 Mod. Ride level in normal position (attach tape measure to rim flange at bottom middle and measure to lower edge of wheel arch) Deviation from nominal value for all wheels together Max. mm 10 Series "15"" rim" 518mm "16"" rim" 531mm "17"" rim" 546mm Low-slung sports suspension "15"" rim" 507mm "16"" rim" 520mm "17"" rim" 535mm Rough road package "15"" rim" 538mm "16"" rim" 551mm "17"" rim" 566mm Issue status (12/2007) Ea am pe masina jante de 17 oe cu suspensie standard din cate mi-am dat seama, la masuratoare mi-a iesit fata 590 mm si spate 570 mm. La verificarea de anul trecut de la autotest mi-a rezulatat ca suspensia fata e la ~55% si spate la ~87%
  4. Dan_316i replied to Atty's topic in Seria 3
    cel verde din stanga(banuiesc)
  5. ok, adica exista dyno test in cluj, cat e verificatul ?
  6. Adica vrei sa zici ca faci din interior recaro vadare ? si modificare la tetiere ...
  7. cu pla, poze "live"
  8. vezi ca am editat super ok si pe ud si pe uscat
  9. http://ssl.delti.com/cgi-bin/rshop.pl?details=Ordern&cart_id=67601200.139.773&typ=R-166219&ranzahl=4&Breite=205&Quer=60&Felge=15&Speed=H&weiter=30&Ang_pro_Seite=10&Transport=P&dsco=139&sowigan=So sari pe ele eu le-am avut, super multumit
  10. mda, diferenta este insesizabila la ochi, dar la mers se simte
  11. amprenta pe sol e mai mare la 205, in concluzie si aderenta balonul anvelopei, 60 e mai mic si masina coboara putin
  12. mai bine pui 205/60/15 s-au omologat si astea pt e46 316/318, am prieteni cu ele trecute pe stalp
  13. acelasi e36 din 2008 pana in prezent
  14. Dan_316i replied to Atty's topic in Seria 3
    De prosti, asta nici eu nu inteleg, da las ca imi fac eu conversia la climatronic.
  15. Aceasi faza imi face mie la cdplayerul oe de e36, cand merg in zone cu semnal radio slab se opreste din cantat si beepaie pana il opresc sau schimb postul. Pt radio-casetofon oe, am si dela, tot asa face.
  16. Baga poze, m-ai facut curios. Mai mult de o gramada ai schimbat, ala care a avut masina chiar a fost cioban.
  17. Am facut-o eu sapt trecuta dupa servici, tot era vreme frumoasa si nu aveam ce face. Vara trecuta i-am rezolvat problema la usa unui coleg din sibiu, am zis ca nu poate fi mai comlicat decat la el.
  18. Si eu am avut aceasta problema, la mine a fost de vina mecanismul de la portbagaj(mecanismul nu motorasul de centralizata). Rezolvare a fost demontarea sistemului de inchidere curatarea lui si pulverizarea de spray WD40. Job done and work perfectly. La mine ramanea deschis/inchis portbagajul, la tine probabil e vb de mecanismul usii.
  19. mai tu mi-ai furat masina
  20. Done, s-a potrivit :frantics:
  21. Hm l-am probat si nu il ia...
  22. salut, poti sa ma ajuti si pe mine cu un cod pt casetofon bmw revers rds ? bp6262v7012635 65128375665
  23. Aveam o bataie deranjanta in volan pe piatra cubica si drum de tara, reparatia la caseta a fost 6 mil.
