manole2000
Everything posted by manole2000
  1. Salut. Iti trebuie magazia de CD-uri si un cablaj special pentru ea. Cablajul este posibil sa il ai pe masina din fabrica. Dupa instalare iti va afisa CDC pe ecran. Completeaza locatia la profil. Daca esti din apropiere te pot ajuta.
  2. Se poate folosi un adaptor. Cauta adaptor BM24 to BM54 (in cazul in care vrei sa pastrezi cablajul HK intact).
  3. O alternativa la cartelele de orice fel este un modul bluetooth. Pentru cei care au deja telefon retrofitul este mult mai simplu.
  4. "OE = Original Equipment - exactly what is used on the assembly lines when your car was made. Parts were made by the exact same manufacturer, to BMW's specifications, and are usually stamped with the BMW logo. These parts must also meet all the BMW quality control specs for that part, same as any part that's accepted into the production process. OEM = Original Equipment Manufacturer - parts are made by a manufacturer that supplies original parts to BMW. These parts do not have to pass the BMW quality control tests for that part, and do not have the BMW logo on them. Quality of these parts can vary greatly - they can range between the exact same part as the one that's put on the car on the production line (but minus the BMW logo...), to something that wasn't good enough to pass quality control, so the manufacturer just sells them as OEM. Another issue - the part may be made by a manufacturer that supplies parts to BMW, but that part may not be a part that particular manufacturer supplies. For example, ZKW may supply some of the OE lights to BMW. However, if they felt like it, they could manufacturer suspension components, and label them "OEM" - after all, they are an Original Equipment manufacturer, just not for suspension components. Aftermarket - anything goes."
  5. Daca ai cablajul in regula foarte posibil ca modulul de navigatie sa fie codat pentru navigatie monocrom. Saptamana trecuta am fost in Botosani, te puteam ajuta cu recodare pentru color.
  6. Salut, completeaza locatia la profil. M-ar interesa cele pe 16.
  7. Cand ai mai putina motorina in rezervor poti sa desfaci ambele plutitoare sa le cureti si la le masori rezistenta in diferite puncte ale cursei. Foarte posibil ca unul dintre ele sa nu mai masoare corect si sa nu mai aiba o variatie liniara in functie de consumul de carburant (respectiv de nivel).
  8. Indicatorul de motorina arata corect?
  9. Demontezi fulia si cuplajul iar apoi masori rezistenta bobinei de la cuplaj.
  10. Daca ai avut anterior ceva scurgeri de ulei pe la garnitura de la termoflot foarte posibil sa fi cedat chiar cuplajul electromagnetic. Senzor cu eroare poate fi cel de presiune instalatie (situat pe sub farul din dreapta) sau senzorul AUC (situat pe radiator in partea de sus - dar in cazul tau nu are importanta acesta din urma). Cel mai bine desfaci cuplajul (il cureti cu aceasta ocazie), il alimentezi direct si vezi daca functioneaza. Bafta!
  11. Probabil un plutitor din cele doua compartimente ale rezervorului nu mai lucreaza corect. Ai sesizat vreo miscare brusca a indicatorului de combustibil?
  12. Buna Janee, Cum spunea colegul Omar este vorba despre un modul de navigatie MK3. Il poti verifica daca se stinge astfel: scoti cheia din contact, inchizi usa mergi la portbagaj, il deschizi si astepti aproximativ 5-10 minute. Ar trebui sa se stinga. O alta cauza poate sa fie "piesa cu tepi" (sau FSU) de la climatronic sau poate o alarma aftermarket.
  13. http://www.bmwclub.ro/forums/topic/166677-masina-mea/page__p__2284466#entry2284466
  14. Pentru mine cutia automata este o optiune importanta. Personal as fi renuntat la o parte din optiuni in favoarea cutiei automate.
  15. http://bimmer.work/ Ti-ar mai putea lipsi oglinzi retractabile electric, airbag-uri pentru pasageri spate, reglaj lombar, modul bluetooth, modul TV, senzor presiune roti...
  16. Salut. Ai cablaj pentru ea? Alimentarea ai legat-o (mufa cu 3 pini)?
  17. Ia in calcul si filtrul de benzina. Cand ai timp da-mi un telefon s-o vad si eu.
  18. Ti-am trimis pe celalalt topic pe care l-ai deschis cu aceeasi problema.
  19. Salut. La E46 semnalul video pleaca de la MK4, intra in TV si mai apoi merge in monitor. Exista un cablaj retrofit pentru modulul TV la E46 care are doar navi. Este ca un Y (alimentare si semnal video) + doua fire care merg in BM54 (sunetul TV).
  20. Verifica si pinii 3,4 si 10 din mufa C daca sunt ocupati. Mai poate fi de la AUX-IN.
