chas3
Everything posted by chas3
  1. Fara mutilari, nu. Mai bine iti iei cu facelift direct.
  2. Inca mai scrii pe forum, deci nu a fost chiar total :)
  3. Senzorii sunt ok, nu? Incearca cu primul tester cu care ai zis ca mergea.
  4. chas3
    xenon
    Ce au de sunt URATE? :blink:
  5. De ce e intrerupta gradatia din poza, la ZR-uri?
  6. Se pot schimba. Oricum, daca ramai cu casetofonul stock nu o sa observi cine stie ce diferenta. La fel si invers, daca schimbi doar headunit-ul si ramai cu boxele stock.
  7. Daca era de la unul din senzori presupun ca se aprindea si celalalt indicator. Dar ne spune mixxed mai exact cand se intoarce :blink:
  8. Dupa manual: "CHECK BRAKE LININGS: Have the brake pads inspected by your BMW center." :blink: "Brake system Brake fluid level The warning lamp for the brake hydraulic system comes on, or the "CHECK BRAKE FLUID" message appears in the Check Control. The brake fluid level is too low in the reservoir. If the brake fluid level is too low and brake pedal travel has become noticeably longer, there may be a defect in one of the brake system's hydraulic circuits. Proceed to the nearest authorized BMW center. Higher brake application pressure may be necessary under these conditions, and brake pedal travel may be significantly longer. Please remember to adapt your driving style accordingly. The warning lamp comes on together with the "CHECK BRAKE PADS" message in the Check Control." Deci mai probabil lichidul decat palcutele, daca zici ca tocmai le-ai schimbat.
  9. chas3
    Angel Eyes
    Asa e si normal :blink:
  10. Victima gangsterului ar fi fost in portbagaj, nu gangsterul :blink:
  11. Incearca pe un Passat de exemplu. Chestia aia nu are legatura cu "clima" de pe BMW.
  12. chas3
    X - Coupe
    Mai avea putin si punea ceasurile alea in portiera. :blink:
  13. Sigur te referi la BMW? Ca procedura aia mergea la VAG :blink:
  14. Adica o sa revina cu detalii :) (cred :) )
  15. Erm.. sa inteleg ca nu era de la valva?
  16. Mi s-ar parea mult mai simplu si mai sigur sa ii intreb direct pe cei de la RAR. http://www.rarom.ro/caros.htm
  17. Mai profesional ar fi fost sa zica: "Nu are nimic, merge perfect" :)
  18. Spate. Astea au facut infart total. Alea de pe fata sunt ragusite si ele pe la 15 la volum. Later edit: infarct adica :blink: Very late edit: deci ce boxe s-ar potrivi pe fata/spate, sa se auda si bine.
  19. chas3
    my 325 :)
    Sper ca nu pretinzi sa ne inregistram ca sa vedem filmele :blink:
  20. Diametrul e de 16 (fara 1-2mm parca). Si aparent nu sunt Nokia.
