- Past hour
Bala replied to FiveThreeFive's topic in Opinii si editoriale
Eu merg doar cu 20 de grade clima. La orice masina. Si acasa stau cu clima la 20. Ca ziceati de consum: la 33-35 de grade afara, cu clima la 20grade la interior si fara recirculare, consumul de energie este pe la 3kW. La 25-30 de grade afara, scade la 2kW. Deci la 35 de grade afara, cate ore dureaza drumul x 3kW => consumul in kWh dat de clima- 3531 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Nu are niciun trial, ca daca era incercam si vedeam ce si cum.
The components listed below can be assigned to the corresponding wiring harness: Left wiring harness: Right wiring harness: Aerial diversity aerial amplifier Aerial diversity aerial amplifier Hose pipe washer jet Additional brake light Luggage compartment light on tailgate Number plate light Left rear light, tailgate Right rear light, tailgate Rear window locking Rear wiper motor Tailgate/tailgate lock Button for tailgate activation Switch for automatic operation of tailgate Aici ai detalii despre ce face fiecare manunchi de cabluri pe fiecare parte a masinii. "Aerial diversity aerial amplifier" asta e modulul. Daca te apuci sa schimbi singur manunchiul pot sa iti pun intr-un document pasii mai importanti sa ajungi pana la modul. Asta e un alt detaliu de stiut, e cu referire la luminile din spatele masinii, este pentru masini pana in Martie 2007: Connector (1) 12-pin Cable colour Connector (2) 4-pin Cable colour Pin 1 (from production date 03/2007) Grey/green Pin 1 Brown 1.5 mm Pin 2 White/Yellow Pin 2 Brown 2.5 mm Pin 3 Yellow/black Pin 3 White/brown Pin 4 Yellow Pin 4 Red/yellow Pin 5 Grey/brown Pin 6 White/brown Pin 7 Brown/red Pin 8 White/red Pin 9 White/brown Pin 10 - Pin 11 - Pin 12 - Parese ca luminile din spate la modelul de dupa Martie 2007 are un conector cu 3 fire in loc de 4. In conectorul cu trei fire priza are urmatoarele culori de la 1 la 3: Pin 1: White/Yellow Pin 2: Brown Pin 3: Black/Yellow.
Cosminbad started following Activare Faza lunga G20 adaptive led
Ai de pierdut 180 de euro, dar daca e lifetime, nu e un capat de tara. Unele functii in magazin au si functie trial de 1 saptamana. Poti incerca pe site-ul connected drive din tara unde ai contul si poate beneficiezi de trial (sau din aplicatia My Bmw daca ai pe telefon) Eu la X3 f25 am xenon adaptive iar la G01 Led adaptive, ambele cu high beam assistant si ca sa le pornesc/testez functia de „con de umbra”, trebuie sa fie rotita de la faruri pe auto si butonul cu simbolul de faza lunga cu A in mijloc apasat (si sa fie noapte evident). Fara functia de faza lunga nu merge sa testezi pt ca nu orbesti pe nimeni si nu „decupeaza” traficul. De asemenea ai in Idrive un mod pentru mers in UK de exemplu, in care iti dezactiveaza farurile adaptive si beneficiezi doar de on/off la faza lunga automata. Cel mai bine citeste manualul masinii si sigur apare cum se foloseste
- Today
Diodele laser se folosesc STRICT pentru functia de High-Beam a.i. sa mareasca "bataia" fasciculului luminos si doar in anumite conditii bine definite. De asemenea, functia de high-beam se realizeaza si cu diodele LED care sunt montate alaturi de cele laser in acelasi sistem optic. Cele laser asadar vin On-Top peste iluminarea produsa de LED-urile pt HB. Sunt f scumpe aceste diode laser, evident ca nr-ul lor este redus in comparatie cu cele LED. Plus ca mai intervin si niste chestii legate de safety. Pe langa pretul ridicat, dar si a conditiilor de safety, din cauza asta s-a si renuntat la modelele prezente la aceste modele cu laser. Castigul pe de alta parte nu surmoneaza dezavantajele, mentionate mai sus.
Check engine,apoi a doua zi nu mai porneste
tzucul replied to Rodi's topic in Probleme tehnice si rezolvari Seria 1
E electrovalva din compresor dacă merge clima când vrea ea.Se schimba și nu mai ai probleme. -
lillejhon started following Remote Services nu merge dupa schimbare TCM
Salutare, Cand am cumparat masina de la BMW dealer (sh) a schimbat unitatea de TCM de sub plafon. Initial am crezut ca schimba doar bateria, dar dupa pe un vin decoder am vazut ca au schimbat si unitatea. Problema este ca nu merge, de cand am luat masina, Remote Services - cand masina este in "deep sleep", spre ex. dupa ce o incui la cca 15-20 min nu mai pot sa trimit nicio comanda catre masina. Am incercat tot felul de reset, nu a mers, am fost in contact cu cei de la Connected Drive si mi-au zis ca niste date nu sunt in sync si sa ma duc la service. M-am dus la BMW dealer si aia cumva radeau, spuneau ca masina e pentru condus nu pentru a te juca pe telefon, au facut un update de soft au zis ca problema e rezolvata, dar cand am ridicat masina si am ajuns acasa tot nu a mers. Din nou am contactat Connected Drive si aia tot ma trimit la garaj, dealerul zice ca masina nu are nimic. Din ce am citit pe internet e o problema pe server la BMW si trebuie sa faca update la noua serie de la TCM ul schimbat. Unii au rezolvat-o fiind in contact cu cei de la Connected drive (USA). Ma bate gandul sa ma duc la alt dealer BMW, dar tare imi e frica ca pierd o zi fara masina, fac reset la unitate si nu se rezolva. A mai patit cineva asa ceva, dupa schimbarea TCM ului, sau ati mai auzit asa cazuri?
alex230ro replied to FiveThreeFive's topic in Opinii si editoriale
Interesant ce ati pus dar cam sar de 40k daca se cauta versiuni de peste 500km autonomie edit , hmm IONIQ 5 84kWh 2WD 229CP PREMIUM 37k eur asta se incadreaza la fel si IONIQ 6 77kWh 2WD 229CP Premium 36k eur. So my bad- 3531 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Am găsit cabluri,100 € pentru stinga și dreapta. Să verific dacă se potrivește codul. WBAPX51020C144313 . Ăsta e vin-ul de la mașină. https://www.bandel-online.de/elektrik/reparatursatz-kabelbaum/2x-rep-satz-kabelbaum-heckklappe-links-rechts-bmw-touring-e61.html?utm_source=google&utm_medium=cpc&utm_id=17623155765&gad_source=1&gad_campaignid=17335745235&gbraid=0AAAAAD1nwRFysYZ0rgLaGhbcK3QFu-TER&gclid=Cj0KCQjw8eTFBhCXARIsAIkiuOwOi71MJ7ce0CVOTJnMi3BZH0dwMpPi6FSgXhwlGl6aTiVLSYN2SM0aAoIOEALw_wcB
Ai patit cw am patit eu cand am comandat a doua cheie la masina, ca aveam numai una.. si pentru ceva motive credeam ca se duce bateria curand.. (ea in schimb merge si azi.. cu bateria de fabrica, chiar daca am desfacut--o..). Prima data am intrebat prin telefon cat costa o cheie noua cu totul, de-a gata.. la cateva luni, a doua oara am intrebat de cost cand comandam niste alte marutisuri. Mi-au siz un pret atractiv.. (dar uitasem sa intreb pw loc de codul de pornit motor..) apoi ideea de cheie mai ieftina mi s-a infipt in cap cum ni se intampla.. Am sunat si am dat comanda prin telefon. Cand m-am dus sa o iau.. fericit nevoie mare.. ma duc spre masina.. apas buton, s-au deschis usile. Zic bravo am facut o afacere.. bag cheia in bord.. nimic. Hop zic, ce-au uitat astia. Intru inapoi, le explic.. imi iau cheia comandata sa o citeasca.. 5 min mai tarziu.. pai nu e codata cu motorul ca nu am solicitat asta.. (Cum...p.. mea zic in minte..) dar ma linistesc rapid ca imi aduc aminte unde sunt si ce trebuia sa stiu (ca au jucat-o exact pe placul meu.. ) le zic.. si cat costa sa puneti si codul ca sa pornesc motorul (nu mai tin minte parca au zic 75-100 ceva de genul)? Ok zic? ca vreau sa o si folosesc sa pornesc motorul, dar mu mi se pare normal sa separati pretul unei chei in doua, zic... well, zic, nu fac ei politica de vanzari acolo.. Si asa, 1/2 ora mai tarziu am avut cheia codata si a pornit motorul la sfert.. Cu mentiunea lor ca toate celelalte coduri sunt blocate (5 in total si ca alte chei/coduri nu se mai pot face..). Si ti-am zis povestea mea si din alta perspectiva.. ca stiam ca pot fi perversi.. Suna din nou la ei si afla cat costa manuchiul de fire de le spate daca e sa il comanzi de la ei. Nu poate sa coste 800 euro decat totul.. cu munca lor Poate 150... sau poate putin mai mult. Pune VIN-ul ca sa iti indic codul, sau cauta singur pe realoem.com Asta e de la un E61 LCI 2008 versiune Europeana (LHD) https://www.realoem.com/bmw/enUS/showparts?id=PX31-EUR-06-2008-E61N-BMW-520d&diagId=61_2678 Cel mai bine e sa ii suni pe ei sa ii intrebi cat costa un kit de reparatie cabluri la modulul de sub haion.. Ei stiu ca sw stie ca ala "pusca" frecvent si probabil il au pe stoc pe la o alta filiala in tara sau depozitul principal. Ti-l aduc in maxim 2 zile crede-ma.
Într-adevăr. Greșeala mea. Nu prea am avut încredere că o scot la capăt cum trebuie. Dar niciodată nu e prea tîrziu.
Stiu ce e cornering, aici se misca fasciculul de faza scurta, se vede si daca sta cineva in fata masinii si se uita la blocul de diode de faza mica. Pentru cornering este un alt bec in far care se aprinde si se stinge daca semnalizezi sau tragi de volan parca. Viper05: g20 cu faruri non laser decupeaza traficul? E ciudat ca la connected drive nu poti sa faci refund la functie/bani daca nu ti place cum merge in 1 zi sa zic asa.
Alex3245 replied to FiveThreeFive's topic in Opinii si editoriale
- 3531 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Victor Orian started following aerisire instalatia de racire
Nu ai mentionat cand anume insurubez capacul radiatorului, inainte sau dupa strangerea surubului de aerisire?
mgi replied to FiveThreeFive's topic in Opinii si editoriale
La Mazda 6e (care de fapt e un Changan rebadged) e mult mai buna bateria mica. Se incarca de peste 2x mai repede decat bateria mare. Mie personal Ioniq6 nu-mi place ca design, dar asta e o preferinta personala.- 3531 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Era de asteptat ceea ce ti s-a intamplat. Ai primit sfaturi de unde sa incepi posturile anterioare.
goangaus replied to FiveThreeFive's topic in Opinii si editoriale
Da, arata bine. Dar Porsche wannabe?- 3531 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Ciprian01 replied to FiveThreeFive's topic in Opinii si editoriale
Nu stiu de ce nu se vorbeste despre Hyundai Ioniq 6, care a primit facelift acum 4 luni. Din toate review-urile pare cel mai bun pe consum, spatiu interior peste Tesla M3 si incepe de la 38k pana la 45k varianta dual motor de 325 cai. Baza 800v, fast charging, Apple Carplay. Si au lansat si o varianta N super agresiva- 3531 replies
- 1
- electric
- electric cars
(and 2 more)
Tagged with:
Am finalizat astăzi. Nu așa cum mă așteptam. Am fost sunat să merg să ridic cheia. Bineînțeles că nu a funcționat la închiderea și deschiderea ușilor. I-am explicat celui de acolo că pentru asta am venit inițial și colegul lui mi-a recomandat să schimb cheia. Colegul bineînțeles că nu a recunoscut,a spus că asta a fost cererea mea, să schimb cheia. Una peste alta cel cu care am vorbit părea că e mai de meserie.. mi-a zis că sigur am fire întrerupte la haion. La fel fără o verificare in prealabil..tester sau ceva.. așa la ochi. Am întrebat cît costă..am rămas perplex cînd mi-a spus că 800 de euro. Nici n-am mai întrebat dacă e inclusă și manoperă. In concluzie,am fost la reprezentanță,am platit 250 de euro pentru o cheie nouă și am rămas cu aceiași problemă. O să fac o reclamație pentru asta cu toate că e degeaba..și o să încerc să desfac tot de la haion pînă in spate la difuzoare să iau für cu fir la verificat. Ceea ce nu știu este dacă este cumva set de cabluri sau le pot înlocui pur și simplu sau lipi. Cam asta a fost experiența mea cu reprezentanța BMW austriacă..unde clar nu o să mai merg. Faptul că e reprezentanță nu înseamnă că au și specialiști acolo. Zii frumoasă, și mulțumesc pentru sfaturi.
Mazda 6e, e si frumoasa si decenta la pret, arata si bine. Varianta de baza, autonomie 479 km, pret 44 290 Eur https://www.mazda.ro/configurator/MAZDA 6e/5HB/ Varianta full, care arata la interior intr-un mare fel, autonomie 552 km, pret 48 590 Eur. https://www.mazda.ro/configurator/MAZDA 6e/5HB/ Doar tractiune spate, aici poate fi o problema iarna.- 3531 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Eu nu pot să merg cu 16 grade. Dacă merg pe 16 grade, îngheț complet. De obicei țin între 19,5 și 21,5.- 3531 replies
- 1
- electric
- electric cars
(and 2 more)
Tagged with:
si eu am tot farul din mijloc dar nu imi este activata funcita, am vazut-o in functiune pe masina unui prieten, si decupeaza traficul. stie cineva in ce pachet era farul adaptive? eu sunt convins ca nu l-am bifat cand am luat masina da, dar trebuie sa ai minim farul 2 dau laser
Hai ca m-ati facut curios cum functioneaza AHL Farurile le am pe AUTO, activez optiunea din maneta, imi apare in bord simbolul faza scurta + A. Noaptea doar imi schimba de pe faza lunga pe faza scurta, in niciun caz nu imi decupeaza masina din fata. Gresesc undeva? Trebuie sa dau pe faza lunga si incepe sistemul sa decupeze masina din fata? Am schimbat parbrizul pe casco anul trecut la bmw proleasing ploiesti, oare nu e calibrat ceva?
Pai atunci e clar, nu sunt adaptive, acel AHL. Faptul ca daca rotesti de volan stanga-dreapta se muta fasciculul la fel, stanga-dreapta, asta n-are treaba cu AHL-ul si nici macar cu High-Beam Assistant. Acea functie e realizata de functia de Cornering Lights, sunt niste functii aditionale in far care ilumineaza in stanga si in dreapta farului a.i.sa ai o iluminare optima indeosebi atunci cand parchezi, dar nu numai.
Mă bag și eu ca , la F32 dacă mașina vine cu cameră KAFAS, si are farurile Led Adaptive, știe să decupeze mașinile de pe contrasens ?
Announcements
Topics
