This stream auto-updates
  1. Past hour
  2. Sa am asa consum mare , i-as da foc
  3. Today
  4. Altul: 14% la 17.7 kmph, pe o distanță de 9 km, trafic relativ lejer, accelerații moderate (normale), modul Comfort. De asemenea: mereu incerc sa anticipez, să las mașina să curgă, să nu accelerez aiurea între semafoare, etc. Per total, un stil de mers economic. Ce părere aveți despre consumurile astea?
  5. Am martorii aceștia conținu aprinși in bord de la frana de mana DTC și ABS am schimbat acele cabluri de la abs dar nu era aceea problema poate fi de la inelele abs de pe planetare
  6. Eu nu am asa motor dar am inttebat google si asta e raspunsul: " Common Reasons for BMW N13 Overheating: Electric Water Pump Failure: The N13 uses a map-controlled electric water pump which, when failing, stops circulating coolant, causing instant overheating. Faulty Thermostat: A stuck thermostat prevents coolant from circulating through the radiator. Coolant Leaks (Rear Sensor/Hoses): A very common, specific issue is a leaking O-ring on the coolant temperature sensor located at the rear of the engine. Other leaks occur at the water pump housing and radiator hose connections. Failed PCV Valve: A faulty Positive Crankcase Ventilation (PCV) valve, often built into the valve cover, can lead to high engine temperatures. Friction Wheel Detachment: The friction wheel that drives the water pump can detach or fail to connect. Blocked Radiator: Debris, leaves, or dirt buildup between the radiator and AC condenser can restrict airflow, causing overheating. Air in System: The N13 cooling system must be properly bled to remove air pockets after any coolant service" Valva PCV vad ca nu a fost luata in considerare in acest topic. Si cum s-a scris din primele randuri... pompa de apa.. daca e electrica.. (asta se deduce din felul cum se procedeaza la aerisirea sistemului) atunci si ea TREBUIE luata in considerara tocmai pentru ca ar putea sa nu raspunda la comanda de a functiona VARIABIL in functie de temperatura motorului. Aici recomand doar pompa de apa originala din ce am mai citit... O pompa de apa electrica nu e prevazut sa tina mai mult de 100-120k km.. iar unele se pot strica si mai devreme..
  7. Ok. Dacă le-ai montat inapoi sau urmează să le montezin, să pui garnituri noi la ele cât și cuplajele elastice. Urmatorul pas, ridică masina pe elevator și urmărește traseul de evacuare de la iesirea din catalizator. Cel mai important verifică racordul flexibil dacă este afumat sau rupt parțial, atunci trebuie înlocuit neapărat. Dacă lambda de după racordul flexibil nu citește valorile corect , fiindcă gazele ies afară parțial, atunci nu știe ce valori să transmită către ECU. Fiind un motor cu 3 moduri de injecție, este foarte important ca Lambda cât și NOX să fie in stare foarte bună și să citească valorile corecte, fără a exista pierderi de gaze. Totodată, recomand ca după inlocuirea racordului, o ștergere a erorilor și dat readaptare valori Lambda din tester.
  8. V4.25.4-12743 https://mega.nz/file/yoVhEZrR#FvlJO2ld0ZCdp_Sy9Z1Xo2nyYmWRHkczsjzwUkqXsMo
  9. Yesterday
  10. am facut astazi verificare cum mi-ai zis , nu curg
  11. Revin cu consumuri, 90% din timp în modul Eco Pro, accelerații line, start stop dezactivat: - 11.9% la o viteza medie de 21.7 kmph, pe o distanță de 28 km, din care 11 km mers întins pe DN1, iar restul trafic mediu spre greu, prin București orele 18 - 13.6% la o viteza medie de 13.8 kmph pe o distanță de aproximativ 15 km, București, ora 18, trafic mediu spre greu Bujiile schimbate acum 7000 km. Plăcuțe spate schimbate săptămâna asta, totul uns ca la carte. Plăcuțele față schimbate și frânele față aranjate anul trecut. Ulei OEM 5w30, tocmai schimbat. Cam aceleași consumuri văd de când am mașina, dinaintea operațiunilor de mentenanță menționate.
  12. De aerisit dupa procedura producatorului, cu caldura pornita si masina cu contactul pus 15 minute sa se aude pompa, am facut o deja, nu se schimba nimic
  13. Salut, ti-am redenumit si mutat topicul in sectiunea corespunzatoare si totodata le-am sters pe celelalte create care erau fix la fel cu asta doar ca in alte sectiuni.
  14. Cam asa e. Dar ma bucur ca macar au facut un efort, pastrand butoanele "apasabile", in loc sa ia calea usoara si ieftina - touchscreen. Per totall asta chiar e unul dintre punctele forte ale modelului, interiorul pe care unii l-ar considera invechit insa mie mi se pare ca e chiar sweet spotul in combinatia ecrane/butoane, cu iDrive 7. Da, corect, luata de noua. Paradoxal, SH 3L+manuala gaseam doar mai scumpe si fara mixul "corect" de culoare caroserie+jante+dotari. Ori s-au vandut putine ori efectiv nimeni nu prea vrea sa le vanda asa repede.
  15. Mie mi-a mers ok, am descarcat, am pus pe stick. Pun si pe masina mai dupamasa.
  16. Incerc sa descarc dar nu prea merge. O sa incerc mai pe seara. Oricum, Thx.
  17. Ai mare grija, daca o chiulasa e rectificata nu inseamna automat ca nu poate avea fisuri. Sunt de parere sa incerci intai o aerisire a circuitului de racire - insist, conform procedurii BMW, care foarte probabil va fi frectie la picior de lemn, dar, cine stie, poate te-ai nascut tu foarte norocos. Daca aerisirea nu rezolva situatia, atunci iti recomand sa cauti un motor complet, la o firma consacrata si, care iti ofera garantie. In niciun caz nu te gandi la jumatati de masura (= doar blocul motor, sau alte combinatii riscante) si nici la motoare din surse dubioase.
  18. Am facut filmuletul acela imediat dupa ce am scos o din service, ca sa vada mecanicul ca nu e treaba buna. Am mai sunat la BMW intre timp, un mecanic adineauri mi-a zis ca 80% sanse sunt sa fie motorul fisurat, _chiulasa_ n ar avea cum sa fie din cauza ca e rectificata. Si da, in drumul spre tara, i-am completata cu apa de la temperatura de afara, direct in motorul incins, pana s-a spart radiatorul. Ce recomandari mi-ati putea face? Sa iau alt bloc motor?
  19. Nu e o veste prea buna. Iti recomand urmatoarele - in ordinea indicata: 1. Efectueaza o aerisire temeinica a circuitului de racire, respectand procedura BMW pentru acest model. Poate ai noroc si reparatia a rezolvat problema tehnica, iar acum fierbe doar din cauza unei aerisiri incorecte. Este putin probabil, dar este o masura ieftina si trebuie sa incepi cu ea. 2. Sper ca mecanicul a verificat - macar vizual - starea pompei de apa. Daca nu, ar trebui investigat daca functioneaza corect. Probabilitatea de a fi defecta este foarte redusa. 3. Sunt sceptic ca ar fi de vina caloriferul din habitaclu. Dar nu m-as avanta sa-l inlocuiesc decat daca prezinta scurgeri. 4. Daca 1 si 2 de mai sus nu rezolva problema, poti suspecta (fara a fi o certitudine) fisuri sau pori in chiulasa / in peretii unui cilindru. Ceea ce complica foarte mult situatia. Am vazut filmuletul pe care l-ai atasat mai sus. A deschide capacul vasului de expansiune si a lasa lichidul sa tasneasca afara nu e deloc bine pentru motor (lasand la o parte riscul sa te oparesti). Mai grav, daca cumva, pe drumul din Spania, ai completat de cateva ori cu apa rece cand motorul inca era fierbinte - in loc sa astepti macar jumatate de ora sa se mai raceasca, nu e exclus ca atunci sa fi cauzat fisuri in chiulasa / bloc. Tine-ne la curent.
  20. @FiveThreeFive Masina nu fierbea cand am luat-o, am plecat cu ea din Spania, prin Austria a inceput sa manance apa, ii puneam apa si plecam din nou la drum, pana la urma in Ungaria s-a spart radiatorul, am lasat-o la mecanic, mi-a schimbat radiatorul, si apoi mi a zis ca tot fierbe, si in urma reparatiilor ulterioare, am scimbat aproape tot ce ar fi fost de schimbat, si masina tot fierbe. Baga caldura doar pe partea stanga, pe partea dreapta baga putina caldura, dupa ce o pornesc, si apoi baga rece!
  21. Masina este superba si cred ca e o distractie sa o conduci. Pare ca e noua 0 km? nu?
  22. superba masina totusi un mare minus pentru BMW , la cum au lucrat la designul ala sa puna un schimbator manual, e clar ca designul a fost facut pentru automata si apoi au mutat chestii pe consola centrala fara sens ca sa poata acomoda un schimbator manual
  1. Load more activity
