Wolff
Contributors-
1305 -
37
Everything posted by Wolff
Vand set jante originale BMW F10 style 328 18"
Wolff replied to Wolff's topic in Vanzari piese si accesorii BMW
update pret: 380 euro -
un articol mai detaliat, suna destul de interesant; mi-a atras atentia paragraful despre suspensie - introduc standard amortizoare cu 2 zone de compresie. New tech: the next 3 Series’ double-rated dampers explained Twin-rated passive dampers of one sort or another are fairly common suspension technology, many working through secondary internal reservoirs. Most of them are ‘frequency selective’, and so the damper switches from lesser to greater resistance rates depending not on the overall size of the bump it’s dealing with but is based in effect on the steepness of the bump’s profile: on how quickly it’s forcing oil to move from one chamber to another. The 3 Series’ passive shocks are different; they ramp up to a secondary firmer setting progressively and only at one extreme of the suspension strut’s range of travel (the rebound end on the front axle and the compression end at the rear). At the front, the effect is achieved though a secondary ring the damper piston has to push against which is governed by a separate hydraulic circuit; at the rear, the piston runs up against a cone-shaped restrictor at the bottom end of the main reservoir. https://www.autocar.co.uk/car-news/new-cars/first-drive-bmw-3-series-2018-330i-m-sport-prototype Si un filmulet in care se vad volanul si bordul digital
nu cred ca merita; cablajul e dificil de facut, si o sa gasesti greu un electrician sa iti instaleze cablajul + modul + codari; nu iti recomand sa iei amortizoare EDC din dezmembrari mai degraba mergi pe un kit aftermarket, e mai usor de instalat, exemplu http://www.kwsuspensions.com/ddc
doar amortizoarele sunt peste 2500 euro; iti mai trebuie accesoriile montaj amortizor (flansa, burduf, etc) si modulul de comanda + cablaje + plus codarile aferente - inca vreo 4-500 euro; mai adaugi montajul 1-200 euro exemplu pt puntea fata - piesele 1, 6, 7, 8, 9 https://www.realoem.com/bmw/enUS/showparts?id=KS41-EUR-05-2014-F15-BMW-X5_30dX&diagId=31_1064
aproape toti am condus W16
motoarele pe benzina de pe e92 nu sunt foarte fiabile pe termen lung, paradoxal cel mai fiabil dintre ele e 335i daca esti ok cu motorina, 320d e alegerea optima, de preferat cel de 184cp (incepand cu a 2a jumatata a lui 2010). in rest, e92 e o masina fiabila, cu costuri rezonabile de intretinere - ia cu incredere.
subwooferul de hifi are 100w, ampul scoate 160w pe canalele pt subwoofere, asa ca risti sa le arzi destul de repede daca dai volumul la mai mult de 50% (asta e si cauza pt mirosul de plastic ars pe care l-ai simtit). poti vinde subs hifi cu ~400 lei si dai pe un set Match BMW-8D in jur de 900 lei; se monteaza foarte usor (ridici scaunul, desfaci niste suruburi, schimbi boxele in enclosure si apoi operatiunile inverse - cam 20-30 min pt fiecare scaun).
daca vrei, ne jucam impreuna cu softul; eu am reusit sa il configurez sa sune foarte bine pe masina mea (e drept, am schimbat si boxele). nu e cazul sa investesti in boxe noi, poti cauta cu rabdare pe olx niste boxe harman kardon originale, le poti gasi la 100-150 lei wooferele, 100 lei tweeterele; subs HK sunt intradevar mai scumpe, 800-1200 lei. sa fii atent la ce cumperi, sunt vreo 3 modele de boxe; se potrivesc de pe oricare alt BMW F, doar sa fie boxele de tipul potrivit; si aici te pot ajuta.
banuiesc ca ai ramas pe boxele hifi - nu au fidelitate suficienta pt amp-ul aftermarket; ar fi bine sa schimbi macar boxele fata si subwooferele. poti sa te mai joci cu setup-ul amplificatorului, e destul de usor de manevrat; poti schimba mult in bine calitatea, asa a fost la mine.
masina asta e ca aia din banc: "domne esti multumit de masina? ca am vazut ca nu prea cumpara lumea!" sa o stapanesti sanatos si multe drumuri placute! cred ca cei mai multi dintre noi astia de pe forum visam la o asemenea masina...
Eu am facut RAR pt F11 (tot xdrive) pre-facelift in februarie anul acesta - fara niciun fel de probleme; toate F11 au aceeasi configuratie - arcuri pe fata, perne de aer pe spate - asa ca nu vad care e problema lor. O sa ma uit de curiozitate in certificat sa vad ce au scris in el.
Bimmercode
Wolff replied to andrei_alin2000's topic in Probleme tehnice si rezolvari comune mai multor modele BMW
poti sa faci o singura actiune - schimbi drive mode in sport, si setezi din idrive ca modul sport sa modifice setarile pt cutie si trenul de rulare -
vezi aici; codurile difera in functie de tipul de interior https://www.realoem.com/bmw/enUS/showparts?id=XA51-EUR-01-2013-F10-BMW-530d&diagId=51_7849
Gata, am gasit un set de 4 jante egale style 350m, cu un mic compromis - una dintre ele este sudata; pretul pt set a fost foarte bun (350 euro), si nu a vrut sa vanda doar cele 3 jante bune. Asa ca am luat tot setul, si acum caut sa cumpar una bucata janta style 350M 8J et30 - daca are cineva de vanzare sa imi dea un semn. Nu ma lasa constiinta sa pun janta sudata pe masina, desi e bine reparata (pe zona interioara a jantei, nu pe exterior); probabil a fost roluita si a crapat, si apoi au sudat-o.
la masina mea (F11 525xd) pt style 351M imi zice 4 bucati 8.5J et33 cod 36117842652 https://www.realoem.com/bmw/enUS/showparts?id=XB91-EUR-02-2013-F11-BMW-525dX&diagId=36_1527 la F10 525 xdrive pt style 351M sunt 2x8.5J et33 cod 36117842652 si 2x9J et44 cod 36117842653 https://www.realoem.com/bmw/enUS/showparts?id=XA11-EUR-02-2013-F10-BMW-525dX&diagId=36_1527 ma gandesc ca singura diferenta sunt pernele de aer in loc de arcuri; un tip care se ocupa cu import/vanzari de jante zice ca incape fara probleme 9J cu 275 pe spate la F11, a vandut/montat la cativa; dar parca as ramane la ce zice producatorul (adica toate 4 egale...)
poti face o verificare destul de simpla a uzurii materialului anvelopei - dai cu mana peste muchiile profilului anvelopei, ca si cum ai mangaia-o - daca o simti aspra sau chiar rugoasa la atingere, sigur sunt galagioase; am pus la un moment dat niste cauciucuri uzate vechi si faceau un zgomot infernal, aproape metalic. in alta ordine de idei, ce jante si anvelope ai pe masina? egale fata-spate sau in 2 dimensiuni?
Gata cu retrofitul; ar mai fi nevoie de niste jante M - probabil style 350M toate 4 egale; are cineva montat pe F11 xdrive jante in 2 dimensiuni ? pe realoem.com imi da doar jante in dimensiune egale si pe 18 (4x8J) si pe 19 (4x8.5J). https://imgur.com/a/qte5R4Q
Poate masina a fost intretinuta exemplar de fostul proprietar si nu e nevoie sa repare nimic; o masina foarte dotata cu sub 150k km costa mult mai mult decat una cu peste 230k km; si mie imi place sa adaug dotari la masina, asa ca il inteleg. Mai multe dotari mecanice, mai multe piese de intretinut; sper sa nu fie cazul sa schimbe barele stabilizatoare de la dynamic drive (~2000 euro pe fiecare punte) sau amortizoarele adaptive (1100 euro puntea fata, 900 euro puntea spate).
am pus eu - vezi detalii in topicul masinii mele; clar merita cei ~100 euro; intensitatea e mult peste cea OE - la minim e ok, la maxim a cam mult noaptea; culoarea amber e foarte apropiata de cea originala, iar cea blue e foarte placuta; se instaleaza relativ usor, fara sa tai niciun fir (~1-2h).
sa o conduci cu placere si fara incidente! imi place mult culoarea exterioara. pt upgrade sunet eu am preferat o configuratie custom, hifi se upgradeaza usor; la aceeasi bani cu HK (~1500 euro cu tot cu montaj) suna cel putin un nivel peste HK (volum, bas, claritate, posibilitati ajustare, etc).
poti cauta si pe olx, sunt vreo cativa si pe acolo
luminozitatea se modifica din rotita de langa volan, impreuna cu restul luminilor ambientale; din pacate sursa de lumina este foarta slaba (un singur led pt fiecare trim).
nu se poate mari intensitatea, sursa de lumina e prea slaba (e un led care genereaza lumina, si se propaga prin tubul cu fibra optica).
