- Past hour
Alex3245 replied to FiveThreeFive's topic in Opinii si editoriale
Mașinile electrice revin în forță. Pe piața europeană, Volkswagen este noua locomotivă- 3479 replies
- electric
- electric cars
(and 2 more)
Tagged with:
- Today
TheIulian76 joined the community
admirb joined the community
Tinand cont de faptul ca Mercedes se gandeste sa cumpere motorul de la BMW pe benzina, asta spune foarte multe despre acest motor B48
BaXXon replied to FiveThreeFive's topic in Opinii si editoriale
Pt cumparatorul de rand , top speed-ul e fara valoare . Autonomia e criteriul primordial , apoi confort etc- 3479 replies
- 1
- electric
- electric cars
(and 2 more)
Tagged with:
B58 are cele mai mici probleme si este cel mai fiabil motor din gama bmw din prezent.Sa nu uitam ca sunt mai multe B48 și B58 decât orice varianta diesel pe piața în lume.Diesel....doar în Europa.De exemplu uite ce probleme are un B57 (diesel) Common BMW B57 engine problems include EGR cooler failure, high-pressure fuel pump issues, turbocharger wastegate problems (often a rattling sound), and intake manifold swirl flap issues due to carbon buildup, especially with short-trip driving. Other concerns include high oil/coolant consumption, DPF clogging from short journeys, potential timing chain issues over time, and fuel leakage into the wiring harness from failed fuel sensors. Specific Engine Problems High-Pressure Fuel Pump (HPFP) Failure: The HPFP can fail due to a design flaw, potentially causing damage to injectors, the DPF, and the EGR system. Turbocharger Wastegate Problems: The electronic wastegate actuator on the B57 turbo can develop issues, causing a rattling noise at low speeds or during deceleration. Intake Manifold Swirl Flap Issues: Carbon buildup can clog the intake manifold and cause the swirl flaps to stick, affecting performance. DPF Clogging: Short driving distances can prevent the Diesel Particulate Filter (DPF) from regenerating properly, leading to soot buildup. Fuel Leaks: The fuel sensor on the high-pressure fuel pump can fail, allowing fuel to leak into the engine wiring harness and potentially damage the Engine Control Unit (ECU). EGR Cooler Failure: The EGR (Exhaust Gas Recirculation) cooler is prone to failure, especially from frequent short journeys, leading to coolant leaks and potential engine overheating. Symptoms to Watch For Loss of Engine Power: A common sign of a faulty turbocharger or engine management system issue. Unusual Engine Noises: A rattling from the turbocharger wastegate or other mechanical noises. Excessive Exhaust Smoke: White smoke can indicate coolant burning, while blue smoke suggests burning oil. High Oil or Coolant Consumption: Indicates a potential issue with the engine or its gaskets. Check Engine Light: Can be triggered by various issues, including a faulty DPF pressure sensor or turbo problems. Rough Idle or Misfires: Symptoms of problems with the fuel injectors. Preventative Measures Use High-Quality Fuel: This can help prevent injector and DPF issues. Regular Maintenance: Adhering to scheduled maintenance, including oil changes, is crucial. Longer Drives: Occasionally taking the vehicle on longer, higher-speed drives can help the DPF regenerate. Fuel Additives: Using fuel additives can help keep the injectors clean and prevent fuel system problems. Monitor Coolant and Oil Levels: Regularly checking these can help you detect leaks or consumption issues early.
Aceste probleme sunt generale si se aplica tuturor motoarelor, nimic nou, specific.
Nu ti spun. Eu cred ca mai trag de M40d mult si bine
Nu-mi spune ca 550e sau X3 M50i are aceasta motorizare
Ciprian01 replied to FiveThreeFive's topic in Opinii si editoriale
Pentru mine nu are nicio valuare acest top speed record, uita-te cat de greu e de controlat si cum face pe cele 3 benzi, calitate de China, uita-te dupa si la Bugatti sau Koegnisegg- 3479 replies
- electric
- electric cars
(and 2 more)
Tagged with:
alex230ro replied to FiveThreeFive's topic in Opinii si editoriale
Pai 330e nu e masina electrica dar as zice ca e urile sunt luate ca masini de "flota" la preturi relativ mici si de aici preturile mai mici sh?- 3479 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Viper05 replied to FiveThreeFive's topic in Opinii si editoriale
ca si cumparator de masina electrica sh cred ca iti cumperi masina pe viata. inca mi se pare foarte ciudat ca un 330e sh (care de nou costa cu 5/6k mai mult ca un 320i) e mai ieftin decat un 320i pe piata sh- 3479 replies
- electric
- electric cars
(and 2 more)
Tagged with:
sskkaa replied to FiveThreeFive's topic in Opinii si editoriale
- 3479 replies
- 1
- electric
- electric cars
(and 2 more)
Tagged with:
Common issues for the B58 Gen 3 engine include potential problems with the rocker arms and valve springs, possibly related to the cylinder deactivation system, which can cause damage to the valves and exhaust cam. Other early reliability concerns reported by mechanics include a bad batch of parts for a specific production range, and the possibility of the issues being more widespread but less documented, rather than a widespread problem. Potential Gen 3 B58 Problems: Cylinder Deactivation System: Some reports suggest issues with the cylinder deactivation system (used for efficiency), which could lead to damaged rocker arms, valve springs popping out of place, and scratched exhaust cams. Valve Springs: Valve springs on some units have been observed to pop out of position or break, preventing valves from opening and closing properly. Damaged Exhaust Camshaft: The exhaust cam can also become damaged or scratched in conjunction with valve spring issues. Context and Severity: Early Reports: These issues are being reported as early reliability concerns by mechanics, but the widespread nature of the problems is still being assessed. Specific Production Runs: Some of the issues may stem from a bad batch of parts from a specific production range. Root Cause: The issues with the valve springs and rockers might be linked to the efficiency-focused cylinder deactivation system in the Gen 3 B58. What to Do: Stay Informed: Keep an eye on forums and owner discussions to monitor the prevalence and details of these issues. Vehicle Service: If you encounter any performance issues or a rough idle, have a qualified BMW technician inspect the engine. Check for Recalls: Be aware of any voluntary recalls related to your vehicle's production date and have any affected parts addressed.
Realist vorbind din ce tin eu minte - actuatoarele vanos, mizeria aia de oil filter housing , busonul vas expansiune si pcv astea am tot vazut pe forumuri, a daca te mananca spatele si faci ceva stage "x" o sa ai sanse sa mai crape si altele in general injectoarele plecau la plimbare si daca nu erai atent pleca si motorul la un moment dat .E masina sh pana la urma .
f11 Eroare 298800 - Nu mai trage in turatii joase
Galagie replied to enders's topic in Probleme tehnice si rezolvari Seria 5
O sa curat dde, stiu ca e destul de a naibii de desfacut, in special din cauza "smeclaului" de etansare, acolo mai am si microcontrolerul unde sunt sanse foarte mari sa fie in capsula BGA ( cu bile), am vazut ca se poate incovoia destul de tare pcb-ul cand se incearca dezlipirea de pe radiator.... O sa fac un backup de software inainte, si apoi sa vedem ce putem face la dde. Multzam tare pentru sfaturi -
Common problems with the B58TU2 engine include oil leaks from the oil filter housing or valve cover, coolant loss potentially due to minor leaks or head gasket issues, and issues with VANOS solenoids affecting engine timing. The disintegration of lower-quality oil filters can also cause blockages and leaks. Oil Leaks Causes: Leaks can stem from the oil filter housing, valve cover gasket, or the cylinder head gasket. Symptoms: You might notice a burning oil smell in the cabin, smoke from the engine, or oil on the spark plugs. Resolution: Regular maintenance and prompt replacement of seals and gaskets are key to preventing and addressing these leaks. Coolant Loss Causes: Minor coolant loss might be due to faulty seals, a loose coolant tank cap, or a failing water pump. More serious issues can include cracked coolant hoses, a damaged radiator, or even a blown head gasket. Symptoms: Low coolant levels in the main or secondary tanks. Resolution: Check for obvious damage to hoses or the radiator. Ensure the coolant tank cap is secure and the cooling system is properly sealed. If the loss is severe, a professional diagnosis is needed. Oil Filter Disintegration Causes: Using low-quality oil filters or not replacing them as frequently as recommended can lead to them disintegrating inside the engine. Symptoms: When a filter disintegrates, small pieces can cause blockages and leaks in the engine system. Resolution: Always use high-quality OEM or reputable aftermarket oil filters and ensure they are replaced according to the maintenance schedule. VANOS Solenoid Issues Causes: Infrequent oil changes can lead to buildup in the solenoid, which controls the engine's variable valve timing. Symptoms: Problems with the timing system's solenoid can manifest as reduced engine performance or rough idling. Resolution: Regular oil changes and prompt cleaning or replacement of the solenoid can help prevent these issues.
officer joined the community
Majoritatea problemelor scrise mai sus sunt regasite pe primele variante de B58.Dupa 2020 multe din ele sunt rezolvate (variantele TU).Acuma dacă bagam și B58 la bmw-uri de evitat ce sa zic.....
enders replied to enders's topic in Probleme tehnice si rezolvari Seria 5
Eu la senzorul de motorina i-am scos garnitura de etansare sa nu mai impinga motorina pe fire cu asa mare presiune, in caz ca se defecteaza iar. Recomandarea mea este sa mai cureti odata toate mufele si sa duci dde--ul la cineva care stie sa il verifice/curete bine, asta pana nu crapa de tot. -
zeronoo replied to enders's topic in Probleme tehnice si rezolvari Seria 5
Nu. E doar o chestiune de timp pana cand o sa moara definitiv. Deocamdata. -
Alți idioți pe strada https://observatornews.ro/eveniment/a-sarit-in-aer-5-metri-o-cursa-nebuna-in-capitala-sa-incheiat-la-spital-pentru-un-sofer-de-20-de-ani-629399.html
- Yesterday
Ai cumpărat o?
bimmer90f30 started following B47 consum exagerat de ulei plus presiune in capacul culbutorilor
Nu exclud să fie segmenții, însă mi-e greu să cred că la numărul ăsta de km și viața relativ scurtă, deja segmenții au probleme. Mai am două BMW-uri. Un 318i din 95 cu 280k km, consum ulei 1l/5000km, un 523i din 2006 cu consum de 1l / 4000km. Și acum brusc asta cu 120k km și din 2016 să consume 1l la nici 1000km in contextul in care in trecut nu era nevoie de completare de ulei de la schimb la schimb.
Atunci e uzat fizic butucul. Canelurile cheii nu mai imping pinii din butucul cheii ca acestia la randul lor sa impinga contrapinii (cu arcuri in spatele lor din partea fixa a butucului.. ca tu sa poti invarti cheia.. Contactul se pune ulterior dupa rotirea cheii.. Nu scapi pana nu demontezi butucul si vezi ce e acolo.. Cauta unul SH..
bimmer90f30 replied to enders's topic in Probleme tehnice si rezolvari Seria 5
Sa fiu tu as duce DDE la demontat, cel putin carcasa. Mufa DDEului se inchide ermetic pe DDE Asta inseamna ca aerul nu intra in conector. Asta inseamna ca motorina este impinsa cu presiunea scapata din conector (vreo 4 bari) prin fire.. si NU se opreste in conector! Pentru ca acesta fiind inchis ermetic (ajuta) sa ajunga motorina in DDE. Conectorul mama/tata sunt foarte apropriati unul IN altul ca atare motorina intra usor in DDE.. mai ales daca acesta este sub conector.. cum e la X1.. practic picura in el. E drept, componentele sunt protejate de un strat protectiv de lac.. dar cat o sa reziste acesta in fata motorinei. Asta e ultima problema care ar trebui ignorata, parerea mea; o problema cu DDEul. -
DDE-ul a scapat sau nu? Eu am schimbat senzorul preventiv cu original dupa ce a aparut eroate de presiune pe senzorul ala la diagnoza periodica cu ISTA.., sters-reaparut-sters-reaparut eroare.. apoi schimbat. Dealerii stiu dar tac malc.. Pentru toti ceilalti.. mufele nu sunt problema mare.. (se spala cu spray de contacte) ca ajung motorina la ele.. problema e cand ai motorina in conectorul DDE. Ala e semn ca deja sunt sanse foarte mari sa fi ajuns si in DDE. iar asta nu e un semn deloc bun!
Announcements
Topics
