Past hour
BMW X3 (G01) M40d Sonnenstein-metallic
Mai e multa pana... departe :)) Maxim inca un 5k km pana la final de an... deci aprox 45k km anul asta... A mea e mai precoce, a trecut deja la cazan, urmeaza rangul de tigaie dupa 250k km...
Android Auto pe NBT-EVO ID 5/6
Ma refeream daca merge prin cablu și nu prin BT
Vand BMW E90 325i
4500 EUR Am pornit-o ieri dupa ~2 luni, ca tot coborasem la ea sa-i pun lichid de parbriz de iarna :)
Today
Recomandare service Timisoara
Pe ulei, nu te lua doar după 5W-30: verifică aprobarea BMW de pe bidon și cartea mașinii. Din ce știu, Motul 8100 X-clean+ 5W-30 are LL-04, nu LL-12 FE sau LL-17 FE+. Dacă F40-ul tău cere aceste norme, nu e potrivit și poate complica garanția. Cere service-ului să folosească exact uleiul cu aprobarea cerută și păstrează factura. La 43k km, schimbul la 10k km sună rezonabil; BBV poate fi ok dacă îți confirmă în scris uleiul și aprobarea.
Salut
Since the high-pressure pump ECU was just repaired, I’d first check whether a diagnostic tool can communicate with the DDE/engine ECU at all. If it cannot, inspect the ECU’s power feeds, grounds and main relay, and confirm the repaired unit was properly coded/aligned to the car. If it does communicate, read the stored faults before cranking further. Only the ABS and airbag lamps coming on may mean the engine ECU is not waking up or communicating on the bus, rather than a separate ABS/airbag fault.
Thinking about a Bluetooth OBD2 scanner for my E90 — which one actually works well?
I drive an E90 320i and want to start reading and clearing codes myself instead of paying a shop every time a warning light shows up. I've been looking at Bluetooth OBD2 scanners that pair with a phone, and one name that keeps coming up is BlueDriver. I don't have personal experience with any of these yet, so I'm trying to figure out what's realistic before spending money. My main concerns are whether a generic Bluetooth scanner can actually read BMW-specific modules or just basic engine codes, and whether live data is reliable enough on an older car like mine. I also don't want to deal with connection dropouts or an app that only half-works on Android. For those of you already using a Bluetooth OBD2 setup on your BMW, what has worked for you? Does it cover more than the engine, and would you recommend it for a first diagnostic tool? Any input is appreciated.
Yesterday
Retrofit Ceasuri Bord / Cluster Basic F30 la 6WA/6WB + NBT EVO?
Nu toate headunit-urile au MOST; verifică asta înainte să cumperi clusterul. Din controller nu poți stabili sigur Business vs Professional — decodează VIN-ul după opțiunile 6UN/609 și tipul HU. La NBT EVO, trecerea la ecranul mare este de obicei doar display + codare, dar dacă HU-ul e EntryNav/Business s-ar putea să nu accepte rezoluția. Deci confirmă HU-ul și portul MOST, apoi comandă piesele.
Rechinul meu, Seria 6 E24 635CSI, manual
La CO ~8%, reglajul AFM e probabil simptom, nu cauza. Verifică presiunea de benzină cu manometru pe tur (FPR nou nu garantează presiunea corectă), apoi scurgeri de vacuum și valorile senzorului de temperatură văzute de ECU la rece și cald. Când desfaci capacul, marchează roata dințată și măsoară continuitatea pe toată cursa cursorului; o zonă moartă explică oscilația. Cu wideband-ul poți regla pe ralanti spre ~14.7, dar nu forța valori fixe în sarcină. 1,5 ture de la strâns e ceva mai bogat, însă nu justifică singur 8%.
Countdown to Extinction
No idea, am rămas surprins când am văzut acele anvelope 😆. Astăzi am schimbat cu unele de iarnă Pirelli p zero 2 pncs elect. Asa pare ca restul de prin Europa aveau Bridgestone. Astea pe care le-am luat nu sunt BMW approved, dar cu siguranta sunt mai bune decat ling longurile de vara(giti)
- Countdown to Extinction
Dezvoltate "special" https://giti-tire.eu/ro/stiri/giti-tire-lanseaza-gitisynergy-h3-ca-anvelopa-de-echipare-originala-pentru-bmw-ix1-si-ix2 Pe scurt BMW am zis vrem anvelopa cu specificatiile x,y,z la pretul de 5 eur bucata pare ca baietii astia s-au incadrat . Ma rog mai nou nu sunt capabili sa aiba o conexiune securizata aparent. De ceva timp imi da eroare la bmw.ro cum ca ar fi conexiunea "no secure" Ma rog aici se pot vedea toate anvelopele puse pe i3 https://www.bmw.ro/ro/more-bmw/technology-and-innovation/bmw-tyre-label.html#tireinfoaccordion-a6b6ad9989-item-1275832be0 pare ca mai avem si Nexen, Pirelli, Continental, Hankook si ceva LL? wtf? ooo dar ce avem noi aici? https://eprel.ec.europa.eu/screen/product/tyres/2539818?navigatingFrom=qr probabil pentru piata din China 🤣
hannahmiller joined the community
ISTA-D 4.06.22 Standalone / ISTA-P 3.62.1.003
Salutare, Ma puteti ajuta cu un link pentru ISTA care suporta BMW X3 G01? Multumesc mult!
Lemolo started following ISTA-D 4.06.22 Standalone / ISTA-P 3.62.1.003
A lasat-o usor ca a auzit ca dupa 270k km, trece de la tractor la cazan...
Ursul alb
Pornita din nou azi doar sa fie.. va trebui sa fac asta mai des cred, pare ca se dezamorseaza un tachet si tacane putin primele 20-30 sec.
Pff te apropii de limita psihologica de 300k .Cam putini km anul asta , recuperezi acum pe final de an ? 😁
Capacul iese greu. Trebuie sa bagi lama unui cutter intre muchia capacului si corpul de metal al AFM-ului si sa tai, inaintand cu cutter-ul tangent la metal si cat de adanc posibil, cat de mult poti siliconul (sau ce smac aveau acum 40+ ani) cu care e lipit. Nu o sa reusesti sa il tai complet. Apoi introduci o lama mai rezistenta intre capac si AFM si faci parghie sa indepartezi capacul. O sa te doara sufletul simtind cum paraie siliconul ramas netaiat. Foarte probabil, se va deforma putin buza capacului. Surubul de reglaj are cursa utila de 6 ture, de la complet strans (= amestec mai bogat) la complet deschis (= amestec mai sarac). Daca ajungi la un capat al cursei fara sa obtii reglajul dorit, atunci trebuie sa misti roata dintata cu un dinte in directia corecta si sa reglezi din nou. Repet, vechile tutoriale de pe Internet sunt foarte bune. Din proprie experienta: - inainte de a incepe reglajul AFM-ului, asigura-te ca jocul supapelor este corect, ca nu trage aer fals e undeva si ca motorul este la regim termic normal (= bine incalzit). De preferat, plimba masina cel putin 20 Km, inainte de operatiune; - dupa ce dai la o parte capacul de plastic, monteaza AFM-ul pe motor intr-o pozitie in care poti umbla atat la roata dintata cat si la surubul de reglaj, in timp real (cu motorul in functiune). Ai grija sa strangi corect colierele, sa nu traga aer fals pe langa AFM. De preferat sa fie cu fundul in sus, nu pe o parte. Ramane de vazut daca poti conecta cablul AFM in aceasta pozitie; - cand umbli la roata dintata, seteaza motorul la o turatie stabila de cca. 2200 - 2600 rpm (pune un obiect solid, de grosime potrivita, intre parghia clapetei de acceleratie si stop-ul ei), cu cati mai multi consumatori electrici porniti. Daca ai AC, excelent, porneste-l pe maxim rece. Ideea este sa pui ceva sarcina pe motor, ca sa treci cu AFM-ul de zona in care surubul de reglaj influenteaza semnificativ amestecul, iar cursorul AFM-ului sa nu fie fix peste punctul de maxima uzura a sectorului de carbon. Regleaza roata dintata conform indicatiilor sondei lambda, dar intotdeauna prefera sa fii putin inspre amestec bogat. Banuiesc ca masina ta nu are catalizator, ca urmare poti sa fii multumit cu lambda intre 0.97 - 0.99 (aprox. 14.2 - 14.5 AFR); - dupa ce ai gasit pozitia corecta pentru roata dintata, lasa motorul la relanti si umbla la surubul de reglaj al AFM-ului. Un motor M30 are un relanti mai linistit cu un amestec usor bogat, dar iti recomand sa nu cobori sub AFR 13.8 / Lambda 0.94; - vei observa ca, atunci cand temperatura ambientala este mult diferita de cea la care ai efectuat reglajele, AFR-ul va devia. Sunt limitele tehnologiei de atunci; - cand pui la loc capacul de plastic al AFM-ului, nu il lipi atat de zdravan cum a facut fabrica. Aproape sigur te vei juca din nou cu reglajele, in viitor, deci trebuie sa il poti scoate cu usurinta. In anumite situatii, bujiile NGK ZGR5A te pot ajuta la relanti. Intrucat au varful cu 2mm mai adanc in camera de ardere decat cele "stock", aprinderea este initiata mai in mijlocul camerei de ardere si amestecul arde ceva mai bine (-> scad emisiile de hidrocarburi). Regleaza distanta intre electrozi la 0.7mm. Dar sa nu te astepti sa faca minuni.
10.03.2023 - 52.245km - constatare generala la achizite, diagnoza, resoftare si update de soft motor/cutie/infotainment, update de harti, etc - BMW GRUP WEST ORADEA 10.03.2023 - 52.273km - revizie ulei ARAL + filtre - ANDRION SERV 28.03.2023 - achizitie jante+anvelope 20" incl montaj + reglaj directie, unghi fuga, etc - BMW GRUP WEST ORADEA 23.05.2023 - 59.900km - revizie ulei ARAL + filtre - ANDRION SERV 29.05.2023 - 59.920km - schimb placute frana fata + diagnoza ventilator scaun dreapta fata - BMW GRUP WEST ORADEA 28.07.2023 - 68.080km - inlocuit EGR/Recitor pe campanie - gratuit + gresat usi + constatare mecanica pentru pompa de apa/accesorii - BMW GRUP WEST ORADEA 18.08.2023 - 70.741km - revizie ulei BMW + filtre + inlocuire pompa apa + antigel + simering palier fata + schimb ulei cutie transfer - BMW GRUP WEST ORADEA 13.09.2023 - 72.000km - Stage 1 la A TEAM PERFORMANCE 04.12.2023 - 80.250km - revizie ulei BMW + filtre + schimb uleiuri diferentiale fata + spate - BMW GRUP WEST ORADEA 06.03.2024 - 90.324km - revizie ulei ARAL + filtre - ANDRION SERV 25.04.2024 - 98.772km - schimb placute frana spate ( nu cred ca au mai fost schimbate vreodata ), verificat sistem climatizare ( ca tot vine vara ), completare freon ( lipseau cam 150ml dupa 4ani jumate aprox ) si igienizare clima, care a inclus obligat si schimbarea filtrului de aer - BMW GRUP WEST ORADEA 10.05.2024 - 101.546km - revizie ulei BMW + filtre, inlocuire lichid frana ( era "scadent" in August oricum ) si schimb ulei cutie ZF8HP, si ceva conducta de alimentare carburant ( apro 200lei + TVA) - toate astea pentru suma de 5000lei + TVA - BMW GRUP WEST ORADEA 26.06.2024 - 110.186km - revizie ulei BMW + filtre - ANDRION SERV 06.09.2024 - 121.537km - revizie ulei BMW + filtre - BMW GRUP WEST ORADEA 14.11.2024 - 130.661km - revizie ulei BMW + filtru de aer, inlocuit protectii telescoape fata + elemente suprasarcina?!, inlocuire brate inferioare anterioare stg+dr fata ( troncanea ceva usor la denivelari mici de ceva vreme ) si un reglaj directie - BMW GRUP WEST ORADEA 22.01.2025 - 140.440km - revizie ulei BMW + filtre, verficiare autovehicul, schimb ulei cutie transfer, si lamela stergator spate - BMW GRUP WEST ORADEA 24.02.2025 - 146.708km - inlocuit senzor Nox dupa DPF, si curatat injector adblue ( nu era f murdar, dar am zis sa-l verifice daca tot e masina la ei ) - ANDRION SERV 28.02.2025 - 146.900km - inlocuit injector Ad Blue, si mufa+conducta - cod 16197381257 ( de la injector la rezervor ) - ANDRION SERV 25.03.2025 - 150.536km - revizie ulei BMW + filtre - BMW GRUP WEST ORADEA. S-a rezolvat si cu rechemarea pentru sinele din portbagaj. 11.04.2025 - 150.536km - inlocuti DPF, original, cu toate cele necesare, coliere, conducte vacum, etc. In urma problemelor cu Sezorul Nox, a dat si o eroare pe DPF, si atunci mi s-a aprins becul. In urma testelor facute, s-a constatat/presupus ca PDF are ceramica crapata, si de acolo erorile continue. Dupa schimb nu am mai avut nicio pb si nicio eroare nici pe DPF nici pe senzor Nox, masima merge perfect. Nu e o problema comuna sau des intalnita, dar mi s-a confirmat ca au mai avut probleme cu DPF-uri crapate si ma masini mult mai noi cu si km sub 100k, putine cazuri, dar a mai fost intalnita problema. - BMW GRUP WEST ORADEA 25.04.2025 - 151.000km aprox - am pus rotile de 19 ( model 887M ) - 245/50/19 - Michelin Latitude Sport 3. De atunci, de peste 5000km, masina merge perfect, si am decis ca voi ramane pe setup-ul asta. Am detaliat in topicul aferent de anvelope problemele, nervii si stresul avute cu rotile. Mi-a ajuns, m-am saturat, si nu mai am nici timp pt pb asta. 07.05.2025 - 154.800km aprox - completat aprox 150-200ml antigel+apa distilata. Am constatat o mica lipsa cand completam lichid de parbriz. Nu au fost notificari in bord sau erori pe subiect, nu lipsea mult oricum. O sa mai urmaresc perioada asta, banuiesc ca poate s-o fi umblat la ceva cand au inlocuit DPF, sa fi curs putin. Sub masina nu par a fi scrugeri, pete, etc. Pana acum dupa aprox 2000km, totul ok. 05.06.2025 - 160.230km - revizie ulei BMW + filtre, schimb uleiuri grup diferential fata + spate, revizie + igienizare clima - completat putin (aprox 100ml) freon - BMW GRUP WEST ORADEA 14.08.2025 - 170.092km - revizie ulei BMW + filtre - BMW GRUP WEST ORADEA 16.10.2025 - 179350km aprox - am facut o verificare/mentenanta preventiva la ANDRION SERV, unde s-au verificat mai multe componente ( galerie admisie, egr, racitor, capac culbutori, pompa apa, role, fulie arbore, mufa senzor presiune, etc ) - inlocuit curea accesorii + 2 bucsi. 23.10.2025 - 180.299km - revizie ulei + filtre, inlocuit ventilator habitaclu, inlocuit discuri + placute spate - BMW GRUP WEST ORADEA 12.11.2025 - 182.920km - inlocuit discuri si placute frana fata - BMW GRUP WEST ORADEA 30.12.2025 - 190.560km - revizie ulei + filtre - ANDRION SERV 23.01.2026 - 193.761km - inlocuit senzor parcare PDC spate (unul din cei vopsiti in culoarea caroseriei ) - BMW GRUP WEST ORADEA (doar de dragul discutiei, senzor vopsit ( culoare Individual - Sonnenstein ) cu manopera - 1700lei ) 04.03.2026 - 200.599km - revizie ulei + filtre, schimb ulei cutie de viteze, schimb ulei cutie transfer, schimb lichid de frana, schimb antigel, ceva furtun de vreo 200lei si o verificare generala, pentru ca ani/km - BMW GRUP WEST ORADEA 16.03.2026 + 2 sapt aprox - 202.127km - Capac Culbutori, Galerie Admisie, Galerie Evacuare, Turbo mic, Suporti Motor + anexe si altele - furtune, conducte, saibe injectoare, garnituri, etansari, etc etc etc + revizie ulei + filtru ulei + filtru aer ( din cauza turbinei mici am mai schimbat odata uleiul + filtrele ) - ANDRION SERV 11.06.2026 - 210.230km - revizie ulei + filtre si electrovalva turbo - ANDRION SERV 17.08.2026 - 221.560km - revizie ulei + filtre - BMW GRUP WEST ORADEA 24.11.2026 - 230.050km - revizie ulei + filtre - ANDRION SERV Au mai trecut 10k km... a mai venit un schimb de ulei. In rest nimic notabil. Merem 'nanthie.
maksymradomskyi joined the community
Merge si sunetul prin boxe ! Ca la orice Android Auto normal !
X1 30e the power of plugin
Vezi ca in cazul asta e posibil sa nu poti sa injectezi, ca e tensiunea prea mare in retea in orele de varf. Si atunci iti trebuie o baterie. Una de 16kwh e pe la 10,000 de lei (ceva decent, cu incalzire si sistem de protectie la incendiu). S-ar putea sa ai nevoie sa pui.
Zero stocuri din pacate...
Nu se mai gaseste nou ? eu imi fac curaj sa iau un debitmetru nou 😁
