Past hour
VAND BMW E92 320d xDrive LCI – Pachet M original – 215.000 km – 8.900 €
Ti-am mutat eu postarea de sub Topicul initial. O pusesei gresit sub topic-ul ce facea referire la cum sa postezi poze in loc sa o lasi in sectiunea generala de Vanzari. Succes la vanzare!
Today
B_D joined the community
Motorul cârâie sau ciricăie la accelerație brusca
Salut, aceeasi problema o am si eu. Acelasi zgomot "de autoaprindere" ca la un benzinar "old boy" ce merge cu benzina proasta, la acceleratie usoara, aprox. 1500 rot. Toata "galagia" asta a aparut, la inceput mai putin si la motor rece, dupa ce am fost la rechemare. Inlocuit EGR, racitor de gaze si MAF. Au zis ca au actualizat si soft. Daca sar de 2000 rot. si accelerez usor energic, dispare.
Zgomot lant X1 N47?
Salut, am vazut si ascultat ce ai postat. Nu pot spune, parerea mea, ca este un zgomot de lant, adevarat. Zgomotul de lant uzat, slab, apare la pornire. Presiunea de ulei intinde lanturile. La turatii peste 2 mii sau la o accelerare usor energica, dispare acel zgomot? O intrebare: ai fost la schimbat EGR pe rechemare?
Anyone using a folding e-scooter alongside their BMW for short city trips?
I drive a 3 Series in Providence and mostly do short urban hops where parking is the headache. I've been thinking about keeping a folding adult e-scooter in the trunk for the last mile, and one option I keep seeing online is the MAXSHOT V1. What I can't work out from listings is whether the folded size and weight are actually manageable for lifting in and out of a sedan trunk every day, or whether the claimed range holds up on real streets with hills and cold weather. I'm also unsure how it handles wet pavement, since Rhode Island springs are not kind. I don't want to buy something that ends up staying in the garage. If you run a folding scooter as a complement to your car, how has the daily fold-and-carry routine been, and would you pick the same model again?
RRobert 19 joined the community
Vand G31 530i
Uite link ul: autovit.roUtilizat BMW Seria 5 2017 - 17 450 EUR, 169 000 km - Auto...Te interesează BMW Seria 5? Verifică oferta disponibilă acum pe AUTOVIT. Descoperă informații detaliate despre echipament, starea tehnică, istoric și preț
Problema boxe fata f34
Problema boxe fata. Acestea au inceput sa se mai auda. Precizez ca am sistemul standard, iar boxele spate si subwooferele de sub scaunele fata funcționează
florin cosmin started following Problema boxe fata f34
florin cosmin joined the community
F10 problema pornire
păi nu am de ce să schimb cutia.. ea schimbă perfect, dar problema aceea nu citește litera la pornire și cade turometrul în mers, am sesizat și faptul ca când las piciorul de pe accelerație o ia turometrul razna
BMW X3 (G01) M40d Sonnenstein-metallic
Dupa ce am mers cu Patrol cu 35uri deja nu mai am pretentii la echilibrare roti am observat ca totul e sa fi la viteza potrivita 😂
Vand BMW E90 325i
Nice, bafta la vanzare , vorbisem si eu cand masina era la Timisoara cu colegul :)
Masina mea De la E46 320d touring la G60 550e
Usor, usor ne apropiem de intalnirea BMW de la Poiana BV. Ca sa nu fiu prins in off side am comandat anvelope de iarna Continental pe 20 runflat aceleasi dimensiuni ca cele de vara, 275/35/20 spate si 245/40/20 fata. 6900 lei toata distractia cu transport si montaj inclus la Sigemo in Constanta. Nu stiu cat de bune sunt dar daca va fi zapada o sa vedem. Cum pe scaunul soferului aveam un mic defect, am fost la AB CT si rezultatul e ca se va inlocui scaunul pe garantie, comanda plasata, asteptam sa vina....la anu' si la multi ani.
Am sunat la clinica de jante si nu face diamond cut.
Vand BMW E90 325i
Vand E90 325i, N52B25, manual, rwd. VIN WBAVB11060VE33412 An: 2006, km actuali 166xxx. Este la mine de 4 ani, luata tot de aici, de pe forum. Are si topic de prezentare AICI. Masina are istoric in reteaua BMW de la 0 km pana in prezent: Pana la 90k -> Germania 90k - 118k -> BMW Timisoara 118k - prezent -> BMW Filaret Istoricul masinii pana la mine: Cumparata de colegul @crtir din Timisoara la 90000 km, in 2017. Full istoric reprezentanta pana atunci. Revizii si intrari numai la BMW Timisoara cat a stat la el. Pe langa revizii, n-a avut de schimbat mare lucru la ea... clasica pompa de apa & termostat + cateva furtunase, nimicuri - 2k EUR in ~5 ani. Am luat-o eu pe final de August 2022, la 118.000 km. Apoi la mine: Initial: Cum am luat-o, pana sa apuc s-o transcriu, a intrat un adormit in mine si a spart bara spate. Schimbata complet pe RCA-ul lui, am si poze de atunci. Detailing Montat folii Lumar pe luneta, geamuri spate si geamuri fata (100% transparenta, doar pentru UV) Montat cea mai buna chinezarie de am gasit-o, o tableta android cu 6GB RAM + camera marsalier Cuparat jante pe 16" style 268 - cauciucurile de vara vin pe ele acum. Am si setul original de jante care are cauciucuri de iarna acum Noiembrie 2022: revizie - ulei, filtre si lichid de frana - 1600 lei Ianuarie 2023: schimbat aeroterma - 1600 lei Februarie 2023: schimbat baterie - 540 lei Aprilie 2023: capac tacheti + garnitura (scurgeri de ulei), garnituri termoflot, conducte tur-retur servo, alte cateva oringuri, piulite, suruburi etc, telescoape capota - 8000 lei. August 2023: revizie + ITP + Discuri frana fata + placute frana si senzori fata/spate - 4840 lei Mai 2024: Inlocuit pompa servo si furtunul cu valva pe sens - 3300 lei August 2024: revizie - ulei si filtre + schimbat solenoizii Iulie 2025: revizie - ulei, filtre, lichid de frana si bujii Aprilie 2026: schimbat amortizoare spate, planetare si senzorii ABS (colierele de pe planetare) - 17000 lei Mai 2026: revizie - ulei si filtre; dat jos baia de ulei, schimbat garnitura, reaplicat mastic, resigilat, etc. - 3500 lei Aveam o mica pierdere de ulei pe la baie. Baia de ulei pe original nu se mai fabrica, asa ca am optat pentru resigilare cu schimbarea garniturilor, busonului, etc. Probleme: E cam cheala :) Stiu asta. Nu m-a interesat decat motorul si partea mecanica cand am luat-o. Macar are scaune incalzite 😃 Are pe plafon urme ca dupa grindina, din cauza faptului ca in TM statea parcata sub un nuc. Probabil ies la PDR, dar m-a deranjat atat de putin acest aspect incat nu mi-am batut capul I-ar trebui un detailing interior pentru ca are niste pete pe scaunul dreapta fata Trim-ul din mijlocul bordului a fost putin ciobit cand mi-au montat navigatia Are julituri de prin parcari pe toate colturile. Mi-a sarit recent o piatra in parbriz cand eram pe autostrada si a lasat o ciobitura in partea dreapta sus. Nu este in campul vizual al soferului. Pret 5000 EUR. Masina se poate vedea in Bucuresti. Anunt Autovit
De-MaRcOnE started following Vand BMW E90 325i
Nu prea am calcat pentru reconditionari, dar ar mai fi si Clinica de Jante - https://clinicadejante.ro/ si Magazinul de Jante din Biharia - https://magazinul-de-jante.ro/ La astia cred ca o sa incerc si eu cu jantele de 20 sa vad daca le dau de capat...
La jante am inteles ca ar fi singurul care reconditioneaza jante cu diamond cut in Oradea. Sau nu am mai auzit eu de altcineva.
- Vând BMW 320d F30, 2.0 diesel, faruri LED, 190 CP, piele, trapa
- BMW X3 (G01) M40d Sonnenstein-metallic
Stiu, dar nah, e cunoscut omul in zona, si serios... https://www.janicauciuc.ro/- Vi se pare corect ce face McLaren?
Si uite asa in loc sa raspunda omul cu, cuvintele lui, raspunde doar chat gpt.. sau mai stiu eu ce bot iar omul doar maniipuleaza/ retransmite (DOAR) ce a intrebat AI-ul. Ceva parere personala exista? Ca asta e forum unde discuta oameni.. Si DA sunt moderatorul propriului meu topic. 🤔🤭Yesterday
- F10 problema pornire
Salut. Lipsa afișării P/D, pornirea doar după mai multe apăsări și căderea turometrului, împreună cu erorile multiple de comunicație PT-CAN, fac mai probabilă o problemă de alimentare/masă sau de cablaj CAN, nu una mecanică a cutiei. Verifică tensiunea bateriei sub sarcină, alternatorul, punctele de masă și mufele de la EGS/selector. Dacă tensiunea e stabilă, rulează planul de test ISTA pentru PT-CAN și linia de wake-up. Nu schimba cutia înainte de aceste verificări.williamscott started following F10 problema pornire- Vand G31 530i
- Problema E46 320d 136cp
Diagnostics is the right next step; don't replace more parts yet. Read fault codes and live data, especially injector 4 needle-lift signal, pump timing/advance, MAF/EGR and boost. If unplugging injector 4 changes nothing, check its circuit and signal before blaming the VP44. Also confirm whether the hard cut at 4000 rpm is limp mode. A worn advance piston is possible, but verify timing and fuel quantity first.thomaswilliams started following Problema E46 320d 136cp- F10 problema pornire
Bună ! am o problema cu un F10.. nu citeste pe bord in ce treapta e dispare litera P iar in acel moment nu invarte motorul trebuie sa dau de 4-5 ori pe buton pana sa o ia, dar nu mereu face asta, uneori o ia din prima, iar in timpul mersului dispare litera “ D “, pe urma reapare, iar turometrul o ia razna in mers coboara pana pe 0 urca inapoi, cutia schimba perfect fara smacituri sau socuri, ma poate ajuta cineva va rog? las si lista cu ce coduri de eroare am S 0235 No No communication possible with: Electronic transmission control S0379 No communication possible with: Gear selector switch CEC40A EKPS, powertrain CAN: Communications fault CD840A DDE, PT-CAN: Communication fault CD040A ZGM, PT-CAN: communication fault CD840A DDE, PT-CAN: Communication fault B7F68C Instrument panel: Selector lever indication, shift point indicator, CAN B7F67B Instrument panel: Wake-up line status incorrect, hardware line E11460 No message (data, display, transmission powertrain, 0x3FD), receivert S 0379 No communication possible with: Gear selector switch E/1413 Message (crankshaft torque 1, OxA5) missing, receiver IHKA, transmittematei cristian started following F10 problema pornirematei cristian joined the community- Problema E46 320d 136cp
- VAND BMW E92 320d xDrive LCI – Pachet M original – 215.000 km – 8.900 €
VAND BMW E92 320d xDrive LCI – Pachet M original – 215.000 km – 8.900 €Vând BMW Seria 3 Coupe E92, facelift (LCI), motorizare 2.0 diesel, xDrive (tracțiune integrală), cutie automată. Mașina are 215.000 km, kilometraj real, și beneficiază de o configurație foarte frumoasă, cu pachet M de fabrică și dotări care oferă un nivel bun de confort și experiență la condus. Dotări și echipamentePachet M original din fabrică Tracțiune integrală xDrive Cutie automată Scaune încălzite Asistent automat pentru faza lungă Apple CarPlay Iluminare ambientală Facelift (LCI) Întreținere și lucrări efectuateDe-a lungul timpului, mașina a beneficiat de intervenții mecanice importante, în special la motor și sistemele auxiliare: Distribuție înlocuită Galerie de admisie curățată Capac culbutori înlocuit Sistem de injecție înlocuit Turbină recondiționată Am preferat să investesc în întreținerea mașinii și să rezolv problemele apărute, în loc să amân intervențiile necesare. Alte informațiiMașina se vinde de către proprietar. Kilometrajul este real, iar istoricul intervențiilor este documentat. Nu urmăresc neapărat un schimb, ci vânzarea mașinii către cineva care apreciază acest model și caută un E92 facelift cu tracțiune integrală și dotări bune. Preț: 8.900 €, negociabil în limita bunului-simț. Mașina se poate vedea în Iași. Pentru detalii suplimentare și fotografii, mă puteți contacta prin mesaj privat.
- Tap the lock icon next to the address bar.
- Tap Permissions → Notifications.
- Adjust your preference.
- Click the padlock icon in the address bar.
- Select Site settings.
- Find Notifications and adjust your preference.
Safari (iOS 16.4+)
- Ensure the site is installed via Add to Home Screen.
- Open Settings App → Notifications.
- Find your app name and adjust your preference.
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
- Select Notifications in the sidebar.
- Find this website and adjust your preference.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
- Click Permissions for this site.
Firefox (Android)
- Go to Settings → Site permissions.
- Tap Notifications.
- Find this site in the list and adjust your preference.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
