- Past hour
goangaus started following Recomandare inlocuire parbriz
Am adunat deja a treia ciobitura in parbriz, asa ca am decis ca voi inlocui parbrizul, pe Casco. Imi puteti recomanda service-uri din Bucuresti unde ati inlocuit si totul a fost ok? La Bavaria Baneasa nu mai calc, mai mult au stricat decat au reparat acolo, la Bavaria Otopeni este mult mai OK dar merg doar cand trebuie, din cauza preturilor mult peste pretul pietei. In rest experiente foarte ok cu FRK Otopeni si Axm Otopeni pe mecanica/revizii. Recomandati parbriz original sau altceva, merita diferenta de pret? Fac pe casco dar nu as vrea sa-mi explodeze polita anul urmator, ca reprezentanta factureaza $$$ fara numar.
- Today
BaXXon replied to FiveThreeFive's topic in Opinii si editoriale
Cum ai zis fara sa specifici diferența , umed sau uscat, ca nu e totuna ...... Citestee mai sus întrebarea !- 4072 replies
- electric
- electric cars
(and 2 more)
Tagged with:
alex230ro replied to FiveThreeFive's topic in Opinii si editoriale
Discutia de de "cityray" adica Geely , nu am studiat sincer ce si cum are , dar KIA nu era in ecuatie.- 4072 replies
- electric
- electric cars
(and 2 more)
Tagged with:
1000+ CP in poza de mai jos.
mgi replied to FiveThreeFive's topic in Opinii si editoriale
Da, cum are și cityray, după cum am zis- 4072 replies
- electric
- electric cars
(and 2 more)
Tagged with:
- Yesterday
bimmer90f30 replied to FiveThreeFive's topic in Opinii si editoriale
KIA: "In the Kia lineup, dry-type dual-clutch transmissions (DCTs) are typically paired with smaller, front-wheel-drive engines. You will find this specific dry-clutch setup across several models equipped with the 7-speed DCT, including the Kia Ceed, XCeed, Kia Niro (Hybrid), Kia Stonic, Kia Seltos, and Kia Sportage" BMW M: "None of the BMW M models use dual-clutch transmissions (DCT) with dry clutches. Whenever an M car was equipped with a dual-clutch transmission (like the M-DCT on the M3, M4, M5, or M6), it utilized a wet multi-plate clutch system. 1. Dual-Clutch Models (All Use Wet Clutches) BMW M's dual-clutch gearboxes (M DCT) used oil-submerged, wet multi-disc clutches for better thermal management and smoother engagement in a high-performance setting: [1, 2, 3, 4] BMW M3 (E90/E92/E93, F80) BMW M4 (F82) BMW M5 (F10) BMW M6 (F12/F13) BMW Z4 M Roadster/Coupe (First-generation utilized the SMG automated manual, which also utilized a hydraulic wet-clutch/actuator system) 2. Manual Models (...Traditional Dry Clutches) If you are strictly looking for a dry clutch, your only option in the BMW M lineup is a traditional, three-pedal manual transmission, which utilizes a traditional dry, single or twin-disc clutch system. [1, 2] Models that offered (or still offer) a manual gearbox with a dry clutch include: BMW M2 (Current generation, along with the previous F87 M2 and M2 Competition) BMW M3 (Available on the current G80 generation) BMW M4 (Available on the current G82 generation)" In concluzie DTCul de la BMW nu e nicidecum DTCul de la KIA.- 4072 replies
- 1
- electric
- electric cars
(and 2 more)
Tagged with:
Eu merg cu 330i ul de 4 ani la frk service. Nu am nimic de reprosat. Nu au incercat niciodata sa imi bage piese pe gat, chiar mi au zis ca nu e cazul sa le schimb dar am insistat eu sa fie schimbate preventiv. Preturi mult mai ok fata de reprezentanta. Am facut la ei de la schimb de ulei motor, cutie de viteze, de transfer, diferentiale, amortizoare, geometrie etc. Sunt super ok.
rubanj joined the community
Cum au toate M-urile din seria F, plus M3 din seria E.- 4072 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Ieri si azi am avut de ajuns in acelasi loc si dupa care la birou plecand la aceeasi ora de acasa. Ieri am fost cu X5-ul si azi l-am lasat acasa ca nu am vrut sa mai pun mile pe el, avand deja 1126 asa ca incerc sa il duc la schimbul de ulei cand revin din Romania cu aproximativ 1200 de mile. Am condus relativ in acelasi stil, distantele sunt un pic diferite datorita navigatiei care a ales rute diferite in functie de trafic. Pana si locul unde am parcat la birou este acelasi. G05 X5 M60i G60 540i Pun si conversiile din mpg in l/100 mai jos. 26.5 mpg = 8.87 l/100 km 32.4 mpg = 7.25 l/100 km Din ce vedeam pe bimmerpost, V8-ul asta consuma decent, F16-le X6 35i din 2017 de l-am avut avea cam acelasi consum mediu cu, ce am avut eu cand am dat masina in 2020, si comparam masina de 306 CP vs masina de 530 CP.
Multa sanatate!
Pai stii ca V8-urile anterioare au tot avut ceva probleme, asa ca am zis ca sa nu am probleme cu primul V8 de il am asa ca de-asta am fost cuminte cu masina si am incercat sa urmez un rodaj de scoala veche al masinii. Deja mi-am programat schimbul de ulei de 1200 de mile pentru Iulie 10 dupa ce revin din Romania ca acum nu mai am cand sa ma mai duc cu ea, Vineri seara sunt in avion spre Romania. Legat de neamtul tau, sa speram ca nu i-a dat ca idiotul din primii km ca sa ai dureri de cap cu motorul dupa.
Buey, sincer tot incerc sa conduc masina pe holurile spitalelor si inca n-am reusit. Promit sa ma mai straduiesc.
Da. Si injectez. Dar mai lucram si de acasa si le incarcam cel mai des pe timp de zi. Sau in weekend-uri.
am inteles dar ma gandesc ca nu stai toata ziua cu masinile la incarcat pe post de baterii. probabil o mare parte o versi in retea, nu?
Inca nu am. Cea mai mare parte din productie se duce in cele 2 EV-uri Nu avea sens sa pun baterii la ce consum am. Acum pt ca s-au mai ieftinit, ma gandesc sa pun dar nu stiu cand. Nu e graba
ce baterii ai ?
Am reusit si montat si al doilea invertor + 18 panouri solarwatt de 465W. Am ajuns la 17.5kW (am mai gasit loc pt inca un panou). Am invatat ca: - certificatul de prosumator inca este cel initial de 7.5kW. Am injectat o zi intreaga cu peste 13-14kW fara probleme. O sa-l actualizez dar ma asteptam sa decupleze sau dinastea. - intr-o zi cu soare, trec lejer de 100kWh produsi. Ajuta si ziua ca e lunga dar frumoasa productie
Asa, dupa ce vad eu masina si ii tot fac poze ma duc mai departe intr-o sala de asteptare unde instructorul imi spune ca ma asteptau, se pare ca eram ultimul ce aparuse din grupul de oameni ce eram la PCD. Ni se da cate o bratara gen de all-inclusive pentru masa de pranz ce urma sa fie gratis si aia e. Acum cativa ani, parca 3 din ce am citit pe bimmerpost dadeau si o noapte ce includea masa de seara gratis la hotel. Acum, au dat-o doar pe o masa de pranz si apa de baut la discretie sa te faca sa conduci mai rapid dupa cum scria pe sticlele respective. Toate bune si frumoase, ne baga frumos intr-o sala asa zisa de curs unde intra doi instructori cu noi ce ne prezinta una alta. Eram teoretic 6 posesori de noi masini, unii insotiti, altii veniti singuri. Din cele 6 masini ce urmau a fi livrate, 5 erau X5-uri si unul era un X6. Posesoarei de X6 (40i) i s-a spus ca i se va da un X6M Competition, restului cu X5-uri ni s-a spus ca ni se vor da dat X5 M60i-uri chit ca unii erau posesori de 40i, 50e, sau M60i. Ideea era simpla, ti se da motor la fel sau mai mare. Se termina cursul de proza si iesim afara. Suntem impartiti in 2 grupe, fiecare grupa cu, cate un instructor ce era la volanul unui M340i cu tractiune spate. Fiecare masina avea inauntru o statie ce mergea pe 2 cai, sa transmiti si sa primesti desi am fost sfatuiti sa nu vorbim pe statie decat daca este vreo urgenta. Altfel, sa le lasam unde au fost puse in suportii de pahare si sa nu umblam nici la volumul lor. Dupa ce dam toti ok-ul ca auzim instructorul prin statie, plecam la teste. Masinile erau destul de pline de dotari, rotile insa erau pe 20 si suspensia nu era cea pe aer, probabil aveau pachetul de DHP (Dynamic Handling Package) pe ele deoarece stateau destul de bine pe curbe. Mai jos sunt cateva poze cu masina de am primit-o eu. Plecam in urma instructorului grupul de 3 masini, celilalti 3 plecand cu, celalalt instructor. Primul exercitiu a fost de franare, de la 20, 40, si respectiv 55 mph. Initial ne-am uitat la instructor cum franeaza si ne-am pozitionat in dreptul unor jaloane sa estimam unde se va opri. Era vorba de franarea de urgenta cand efectiv apesi pedala sa o rupi si nu o eliberezi pana nu a stat masina pe loc. Eu m-am dus singur asa ca nu a trebuit sa schimb cu pasagerul si am facut de 2 ori mai multe franari. Urmatoarul exercitiu a fost si ceva mai distractiv, si anume pe circuitul lor, pe o sectiune delimitata din jaloane, am dat cateva ture unul dupa altul. Iar, norocul meu ca eram singur si am dat de doua ori mai multe ture decat cei ce erau cu pasageri care trebuiau sa schimbe. Aici... surpriza, am reusit sa supraincalzesc transmisia masinii. Imi tot spunea instructorul sa stau pe loc cand terminam tura ca il prindeam pe cel din fata. De, nu e vina mea ca a zis ca putem conduce cum vrem noi fara limite, doar sa nu dezactivam DSC-ul in rest Sport Plus, cum vrem, nu e problema. Mai departe, au urmat doua ture de circuit, cu masina instructorului cu el in dreapta. Era vorba strict de portiunea rotunda a lui, din pacate nu am nicio poza dar nu e problema, mai ajung eu pe acolo. Asa, era vorba de mers in cerc dar, era ud pe jos ca au avut aspersoarele date drumul sa mearga sa tina pista uda. Ideea era sa vedem cum mergem cu 20 la ora cu DSC-ul pus fara sa patinam dupa care brusc hai cu 40 si a dezactivat DSC-ul. Urmarea, direct invarteala pe pista. Indrept masina, activeaza la loc DSC-ul si mai dam vreo doua ture cu 40 la ora sa arate cum isi face DSC-ul treaba. O terminam si pe asta si hai cate 3 in masina, de data asta in M3 Competition cu instructorii la volan sa ne arate cum se da o tura pe toata pista inclusiv pe portiunea uda.... ceva de genul uite asa se da o tura. Cam dadeau la un maxim 70% din ce puteau cu gandul si sa protejeze masinile si sa nu se intample vreo boroboata sa fie responsabili de oameni. Mai jos sunt cele doua M3-uri cu, care ne-au dat instructorii pe un asa zis "hot lap". Si gata, la pranz cu noi, urma destindere si partea a doua dupa masa. O sa revin cu partea urmatoare a povestii.
- Last week
Zgomot roata stanga fata x3 30e
niculae catalin replied to niculae catalin's topic in Probleme tehnice si rezolvari Seria X
Am rezolvat problema . Amortizorul avea joc in tija . Am schimbat amortizor plus flansa stanga -dreapta -
Marin2020 joined the community
@alex230ro DCT e cutia automata cu ambreiaje uscate? Cum au kia? Nu as lua asta ceva nici mort!- 4072 replies
- electric
- electric cars
(and 2 more)
Tagged with:
Clit Eastwood started following 2026 G05 X5 M60i
Cata rabdare ai avut. Sunt sigur ca la a mea, primul proprietar n-a avut rabdarea asta. Sau cine stie, neamtul... Hai cu finalul de rodaj sa ii dai talpa
Sa te intrebam si cati km ai facut cu masina de cand o ai? Faci 5k km pe an? Noroc ca mai vii pe la cate-o intaknire organizata de mine si mai o scoti si pe ea la drum saraca.
Topics
