9224 -
93
http://www.honestjohn.co.uk/realmpg/bmw/5-series-gran-turismo-2009 1 mile = 1,61 km
...Am ajuns mai tarziu la intalnirea asta.. Se poate poate face re-upload din nou pe Mega? Poti sa spui cam cat de mare este baza de date, progamul ne-dezarhivat? Multumesc.
For those that never believed ..from the start of 2015, ... "Shell premium engine and motorcycle oils to be supplied for BMW service-fills in more than 140 countries " - Link ..."The collaboration means that Shell will produce and supply BMW's branded engine oils. These products will meet the latest BMW engine specifications and are underpinned by Shell's PurePlus Technology. Shell PurePlus Technology is a breakthrough in how engine oils are formulated. It is a patented gas-to-liquid (GTL) process, developed over 40 years of research, which converts natural gas into a crystal-clear base oil. Base oil, usually made from crude oil, is the main component of finished oils and plays a vital role in the quality of the finished engine oil. The base oil is produced at the Pearl GTL plant in Qatar, a partnership between Shell and Qatar Petroleum. From 2015, BMW service customers benefit from the integration of Shell's global lubricants supply chain with its gas value chain in Qatar." :sorcerer: :sorcerer: :sorcerer:
Nu te ..teroriza. Este in regula indicatia data in meniul ascuns. Doar pentru pace interioara incearca sa inregistrezi bateria cu ajutorul INPA. Si mai ales/indeosebi nu mai descarca niciodata bateria sub 11V! Este o tensiune prea mica pentru viata unei baterii cu acid sulfuric.. sub forma de acid..
Ce tip de motor? Adica despre ce model este vorba? EGR-ul e prins in 4 suruburi de admisie, si cu alte doua cleme diferite ca forma si marime.. aici fiind vorba de 320d; 163CP.
Am citit eu destule topicuri pe alte forumuri pentru ca ma intereseaza ce fac ei cu acest motor cu probleme (.. si sa nu iti crezi ca altii NU pus asa intrebare la dealer..) si am aflat ca dealerii sunt destul de abili sa nu recunoasca vreo versiune de motor cu probleme pentru ca asta suna ca declaratie aproape oficiala ca prima editie (sau si a doua) de motorare au probleme deci trebuie sa faca recall la toate masinile dotate cu acele motoare.
...Eu nu m-as atinge/da banii de o masina care a stat intr-un loc mult timp nevanduta! Asta inseamna ca fie nu merita banii, fie are un defect care doar isi cauta "reparatorul".. Parerea mea.
Atunci rulmentul acela trebuie sa fie doar valabil in kitul de Sachs; cautat pe google dupa codul dat si peste tot zice de Sachs. Daca puneti Sachs f. probabil ca asta o sa primiti. Poza de mai sus pusa de tine contrazice ce spun dar aleg sa concluzionez decat sa ma contrazic. Atunci cum se face ca eu am primit rulment doar cu o prindere (suport metalic la spate.. pe aripioarele de sprijin) in kitul LUK identic cu, ce am avut pe masina; E90, M47N2, euro 4, 6 trepte?
Desigur ca vede din pozele de mai sus ca se poate ca rulmentul sa fie rotit la 90 de grade si sa fie in doua pozitii(distante) diferite fata de arcurile/"soarele" discului ambreiaj. Numai ca din 2005 pe E90 rulmentul are o singura pozitie; de retinut pentru cei care trec pe aici si isi fac griji.. Ne-am lamurit acum. Bravo noua!
Volanul se invarte mai greu
bimmer90f30 replied to Horiaaa's topic in Probleme tehnice si rezolvari Seria 5
:goodjob: Sper ca esti incantat ca ai schimbat acel ulei! Mai ales cand vezi in ce stagiu/hal se degradase cel vechi.. Daca vrei poti sa si vezi cum este RECIRCULAT PERMANENT acel ulei trecand prin sita din rezervor si in sistem si ce important este acesta sa fie de cat mai buna calitate (nedegradat). Are ceva viteza de curgere.. (Eu aveam impresia ca uleiul din rezervor e acolo doar sa fie consumat cand cel din sistem se pierde..) -
Fii atent si la cele 2 filmulete de mai jos. Exact acel tip de rulment - cel cu rosu, am gasit montat si am inlocuit la mine. Nu am instalat rulment Sachs si nici kit Sachs; eu am pus kit-ul LUK. se pare ca demonstreaza ca Sachs ar fi mai bun, in timp ce zice de rulmentul LUK ar fi noul design..Din poza ta nu reiese ce tip de rulment este montat acolo (se vede ca este rotit in poza 2..) dar in filmultele amandoua puse de mine, se subintelege (pe aripioarele acelea ale rulmentilor) unde/cum se sprijina furca pe pe rulment.
Trusa de scule, de urgenta, trebuie sa fie intr-un loc accesibil in portbagaj, nu trebuie sa fii nevoit sa cauti mult dupa ea. Nu este unde nenea asta!? E drept ca este modelul E83..
Inca o data, ca sa nu mai fii atat de confuz dupa cum zici "..si in secunda urmatoare ma pot trezi cu martor de ulei in bord"; ..modul de "lucru cu estimatorul" nivelului de ulei din baia de ulei se face in stationare cu, contactul pus, dar fara a porni motorul. Apoi intri in meniu la nivelul de ulei si il interpretezi.. In mers cand tu zici ca te poti trezi cu ulei lipsa, atunci cand de fapt lipseste DEJA un litru de ulei din circuitul uleiului prin motor, lucru indicat de data aceasta de indicatorul de presiune din baia de ulei. Fapt in urma caruia trebuie sa pui ulei cat mai curand fiind sub nivelul de minim, cand iti recomand sa opresti motorul, sa astepti 10 minute pentru ca, cat mai mult ulei sa ajunga jos in baie. Si sa interpretezi nivelul ca mai sus, stationand cu motor oprit, pentru a fi sigur (proba) ca indicatorul de presiune de ulei nu este defect (ceea ce se intampla foarte rar..). Si apoi sa pui ulei daca este cazul.
...daca are/sunt doua pozitii de montaj, de ce nu s-ar vedea sau nu ar mentiona acest specialist [care chiar instaleaza un volant "normal", cu o singura masa (despre care se stie ca sunt anumite riscuri...)]. Vezi video ; de la minutul 5:50 la 9:15 (cand spune clar ca rulmentul, partea din spate a lui se sprijina/aliniaza cu partile laterale ale furcii). Cand eu am demontat si remontat, totul a fost gasit exact ca in clipul prezentat. Si am urmarit si manualul de demontare si reparatii pentru benzina si motorina seria 3 (2005-2008). Nu scrie nicaieri despre doua pozitii, pentru ca daca ar fi fost, obligatoriu ar fi mentionat pentru ca este esential de observat cum este montat! Din nou, cand am schimbat kitul ambreiaj si volantul NU AM VAZUT ca ar fi doua puncte de montaj al rulmentului! 2cm este o distanta ENORMA de montaj in doua puncte diferite pe furca! (...Cred ca o sa raspund numai acelora care au schimbat singuri cel putin kitul! Deocamdata nu am intanit pe nimeni atat de "aventuros"..; decat mecanici de profesie (Premium Service)care rar mai dau p-aci..)
Dupa 8-9k km nu este nimic in neregula daca trebuie sa pui 1 litru. Nu prea se intelege mare lucru despre cum interpretezi/masori (probabil nu poti sa masori pentru ca motorul nu are joja..) Referitor la tipurile de uleiuri folosite de BMW, LL01 vs LL04 si confuzia ta, pot sa spun ca stiu ca norma LL-04 este recomandat in special motoarelor diesel, pentru a proteja filtrul DPF si a arde cat se poate de "curat".. in general. Deci poti folosi linistit ulei din norma LL01 in motorul pe benzina
Poti sa gandesti un pic mai departe? Ai un filtru cumparat de la o sursa destul de serioasa? (poate nu stiai dar filtrele de la BMW sunt toate din hartie si se intampla sa fie ambalate in simple cutii nesigilate) 1. daca filtru e in carcasa metalica, desfa-l acasa daca iti permiti, inainte... daca nu, desfa-l dupa ce il cureti cu diluant cat poti de bine si vezi cum a fost facut, cum a rezista si apoi mergi si cumpara de la aceiasi sursa! 2. numara singur (daca stii )si analizeaza personal calitatea hartiei folosite in filtru cumparat sau pe care urmeaza sa dai banii (daca esti la magazin..) (Mann tin sa spun ca are partile de sus foarte tari, filtrul se simte solid-tare in mana) (e greu de crezut ca inca mai trebuie sa dau asa simple idei..) Videoclipul este pus din mai multe motive, dar mai ales pentru a evidentia tocmai ceea ce arata acela acolo: ca pe piata (chiar cea vestica) pot fi gasite filtre de proasta calitate!
se poate (si personal) compara/dovedi diferenta calitativa/efectiva a filtrelor.
DTC aprins in bord este mai permisiv in sensul in care iti va permite sa scoti masina din zapada... ai acces la toata puterea motorului (iti permite sa faci si donuts daca iti doresti), anumiti senzori sunt opriti - cand DSC/DTC este aprins in bord; deci controlul automat al masinii in sens de franare a masinii (de urgenta) prin intermediul senzorilor ABS, ramane inca activ... Decuplarea/dezactivarea totala a DTC si DSC se intampla atunci cand decizi sa apesi mai mult de 3 secunde pe TDC iar in bord se va aprinde in schimb un cerculet cu sageata la capat si un triunghi cu exclamatie in mijloc de culoare galbena. De aici esti doar pe socotelile si ambitiile tale pe sosea in lumea fizica!
Iti sugerez sa crezi ca Motul 10W40 este full-syntetic de la inceput, pentru ca si daca are fi fost semi.. avand in vedere km trebuie sa fi trecut pe cel procesat chimic aproape in totalitate deja. Eu am peste 3000k km si folosesc 5W40 full-syntetic de la Shell (pure-plus). Numai tu decizi daca mai este cazul sa te ..intorci la 5W30..
E frumos sa iti imaginezi ca masina cu streptonic consuma mai putin decat una ..manuala. Em un 320d manual iar daca vreodata v-a consuma 8-9 litri in oras indiferent de vremea de afara am scapat de ea! Asta e o definitie nu vreun moft sa tin la asa masina.. Si are acum peste 300k km. Cum consuma de la plin la plin? Cat estimeaza calculatorul si cati km faci in realitate!?
Nu. Nu exista asa ceva. Mai ales daca ambreiajul e cu auto-reglare.
Ai schimbat si tubul acela (prins de cutie cu patru suruburi) pe care se deplaseaza rulmentul de presiune cand apesi pedala? S-a schimbat si pivotul acela de plastic (alb) pe care se sprijina furca rulmentului!? S-a verificat starea furcii (cumva indoita, ceea ce ar fi greu de crezut..)? Furca nu am citit nicaieri ca ar trebui schimbata.. dar poate situatia a cerut-o.. Cele doua de mai sus SUNT recomandabil(e) a fi schimbate la schimbul kitului! Nu as suspecta nimic altceva pentru ca ceea ce zici tu ca simti ca merge greu e in ansamblu/mecanismul pana in soarele discului care se pare ca isi face treaba in decuplarea discului de volant.
