rikmh
Everything posted by rikmh
  1. Este sub capota, partea soferului, dar daca tragi de el trebuie sa mergi la reprezentanta sa refaca ceva. Asa scrie la 330e in manual...
  2. Si eu am seria motorului trecuta in carte de RAR, mai ciudat este ca nu corespunde cu seria din serverele BMW (myAir). Pe berbeacul de la RAR l-am vazut cu ochii mei cum s-a chinuit aproape jumatate de ora sa citesca seria de pe bloc si tot nu a citit-o bine, corespund primele 5 cifre apoi pe carte au pus un zero iar in documentul scos din AIR apar inca trei cifre fara zero...
  3. Antena diversity din haion. Verifica intai firele care trec pe acolo.
  4. Este normal. Motorul consuma undeva intre 2 si 5 litrii pe ora la relanti in functie de temperatura. Fa socoteala la 10-15km/h ce inseamna....
  5. The glow system of the N47 and N57 diesel engines consists of the following components: DDE control unit Electronic preheating control unit Ceramic glow plugs LIN bus as interface between the DDE control unit and preheating control unit ................ To activate glowing, the DDE sends the required glow plug temperature to the combustion preheating control unit. Across the LIN bus, the DDE also sends the following operating values to the preheating control unit: Coolant temperature Intake air temperature Ambient pressure Vehicle voltage Injection rate Engine speed Status signal for starter enable The preheating control unit uses these three operating values to determine the required current for the heater plugs and supplies the heater plugs with current. ...................... Communication The DDE control unit and preheating control unit communicate across the LIN bus. The LIN bus is a bidirectional data interface based on the master‐slave principle. The DDE control unit is the master controller.
  6. rikmh replied to Cristi Fra's topic in Masina mea
    Unul sau amandoi nu mai "citesc" viteza rotilor de pe spate, si considera ca masina patineaza, drept pentru care franeaza roata care o vede gresit ca se invarte mai repede, simultan cu taierea acceleratiei. Problema e cunoscuta, cauta pe google.
  7. rikmh replied to Cristi Fra's topic in Masina mea
    Senzorii ABS de pe spate.
  8. Verifica actuatorul de la valva EGR. Se blocheaza uneori la capat de cursa.
  9. Vezi ca exista in ISTA un ABL care iti arata cine a "trezit" masina in ultima perioada ( parca minim 50 ultime "treziri"). Face parte din Energy Diagnosys.
  10. Din proprie experienta, cu toate ca am pus motorina in filtru, de pe conducte a curs destula motorina, astfel incat chiar daca am pus de 3-4 ori contactul fara sa dau la automat, motorul nu a pornit la prima incercare. Aveam la indemana ISTA, am rulat procedura de bleeding si din rezervor s-au auzit bolboroseli puternice. Cand procedura s-a incheiat motorul a pornit instant.
  11. zic si eu... nu are cumva incalzire auxiliara? am mai auzit sunete de genul la masini cu asa ceva
  12. Fa o diagnosa cu ISTA si ruleaza Energy Diagnosys. O sa poti vedea daca sunt consumatori care trezesc sau nu lasa sa intre in sleep masina, close current violation, si alte informatii inclusiv starea de incarcare a bateriei pe ultimele 20 de zile si alte detalii furnizate de IBS.
  13. maro-verde (G =Gauge=ceas indicator) maro-gri (W = Warning = bec avertizare) L= maro = nul/masa/caroserie
  14. Diferenta de diametru exterior -> diferenta de viteza de rotatie anvelopa
  15. Hidden glowing: Up to a coolant temperature of 30 °C, preheating and start standby preheating are activated as so-called hidden preheating. Hidden preheating is triggered by the following signals: • Driver's seat occupancy • Seat belt buckle, driver • Valid ignition key • Terminal R • Brake operated • Clutch operated Hidden preheating is triggered a maximum of four times and then only enabled again when the engine is started. Din motivele de mai sus uneori nu mai apare simbolul bujiilor pe bord. Doar daca totul se succede foarte repede : deschis masina->asezat la volan->apasat start..
  16. rikmh replied to adyyannis's topic in Seria 3
    Da.
  17. La E90/91 LCI caseta este electrica la cele mai multe dintre ele. Se numeste EPS (Electric Power Steering)....
  18. Se repara, se rescrie EEPROM, cauta la tine in oras. Eu l-am rescris singur dar distractia m-a costat cam mult, vreo 550 lei scula cu care se poate rescrie...
  19. Eu nu inteleg cum se dilueaza uleiul cu motorina injectata in DPF, adica pe evacuare ?
  20. "Furtunele *** sunt fabricate din teflon si nu isi modifica proprietatile in functie de temperatura iar ca masura suplimentara impotriva dilatarii sunt imbracate in camasa metalica din otel inoxidabil. Fata de furtunele din cauciuc care au termen de Garantie: 3 ani (dupa 3 ani se recomanda inlocuirea lor insa nimeni nu o face), *** ofera Garantie: pe viata pentru toate tipurile de furtune." Am pus *** la numele marci. Sunt multi producatori, ideea este aceeasi
  21. Sa incerc sa iti raspund pe rand: 2. Cablul pe care il ai e bun. Ti-am spus ca arata exact ca cel pe care l-am folosit / folosesc eu. Subliniez ca doar arata si de asta mai spun ca trebuie sa il testezi mai intai cum se comporta la "munca", in sesiuni mai lungi. Am aflat de ceva vreme ca unele cabluri sunt facute cu componente nu prea ok care se incalzesc mai mult decat trebuie ducand la erori si, crede-ma, nu vrei sa ai module in programing abort. Problema cu ISTA/P nu este ca nu e bun ci doar ca dureaza mult si incearca sa faca totul intr-o singura sesiune care dureaza mult si foarte mult. Mai sunt si alte implicatii : ISTA/P vrea sa monitorizeze voltajul masinii, sa controleze K30 si K15, adica contactul, lucruri imposibile cu cablu K-DCAN, posibile cu ICOM, cauta si intelege ce este ICOM si ce versiuni exista ale acestuia. 3. Modulele mai putin importante sunt cele fara de care masina porneste si poate fi condusa. La mine au fost FZD, FLA, PDC, KLIMA. Ce fac ele in masina gasesti cu Google. La tine unele se numesc altfel dar au acelesi functii. Cu aceste module testezi si daca cablul tau functioneaza cum trebuie in vederea treceri la modulele importante. 4. Modulele care se updateaza pe fibra optica sunt sunt cele din sistemul infotainment (headunit-ul cu componentele lui) sunt suliniate separat in pagina care iti arata "harta" logica a componentelor masinii in ISTA /D /P legate cu o linie rosie(parca) intre ele. Vezi legenda din josul "harti". Documenteaza-te ce este ISTA /D /P(software) ce este ICOM A / A2 /NEXT cu adaptori B, C (hardware). Link-urile puse de tine sunt de cabluri ENET care nu au ce cauta la seria E. La mine a fost simplu nu am MOST, neavand navigatie, amplificatoare,etc. si am putut face update cu cablul K-DCAN, asta dupa ce am "reusit" sa pun MASK/CCC in programming abort 5. iti recomand sa cauti o sursa de server HP si sa o modezi sa scoata 13.6 V si vreo 88 A legata la priza 220. Nu te complica cu alte baterii sau UPS decat daca vrei o sursa de 220V redundanta in cazul daca se opreste tensiunea de la retea. 7. O sa vezi in bord la unele module niste erori ciudate. Se datoreaza , unele dintre ele faptului ca in timpul programarii sunt puse in stare de programare care le face sa nu mai comunice cu modulele celelate, generand la acestea o serie de erori. De aceasta este depreferat ca dupa fiecare modul updatat sa faci procedurile necesare: contactul luat, pus, conectat cu ISTA/D, sters erori, contact luat, contact pus verificat stare cu ISTA/D... asta face si ISTA/P de dureaza asa de mult update-ul cu el. Codarea si eventuala readaptare este necesara , se zice, necesara pentru ca la unele module, se pierd setarile specifice masini din zona flash. La mine sincer nu a fost necesar nici la servo electrica cu toate ca ma asteptam sa trebuiasaca sa reinvete pozitia volanului si nici la cutia manuala unde DDE ar fitrebuit sa invete 0 gear position pt start/stop. Poate am avut noroc. Bafta
  22. Hai sa iti spun din experienta mea. Masina E91 2009. Totul a inceput din curiozitatea mea de a verifica eventualele erori si corectitudinea kilometrajului. Cablul , unul ca cel din poza ta. Dupa doua conectari cu INPA brick-uit FRM-ul. De aici au inceput "dansul". MI-am reparat singur FRM-ul, cumparand un X-PROG si apoi updatat. Apoi am zis ca nu da bine ca din 16 module doar FRM-ul sa aiba data de 2019 :-) Acum serios daca chiar nu poti sa te abti astea ar fi sfaturile mele: 1. Documenteaza-te mult inainte de orice pas. 2. Foloseste WinKFP si ai grija la setarile acestuia. Nu folosii ISTA/P cu acest cablu pentru update. ISTA/P il poti folosi doar eventual sa identifici la care module ai versiuni mai noi de soft, dar doar atat, nu mergi mai departe cu programarea si codarea. 3. Faci update intai la modulele mai putin importante fara de care masina poate functiona daca ceva nu merge bine. 4. Nu te atinge de modulele care sunt pe fibra optica, pentru acelea iti trebuie ICOM cu adaptorul pemtru MOST 5. intotdeauna folseste o sursa de tensiune stabilizata(NU redresor de incarcat baterii) care sa scoata minim 13.4 V si minim 50 A 6. Ai grija CAS are o procedura speciala de update, si nu esti avertizat niciunde in program (de genul: se porneste update-ul dupa ce ai scos cheia din contact, nu deschizi usi, geamuri si nici nu respiri :-) ) 7. Inainte si dupa ce faci update la cate un modul verifici erori si le stergi. Unele module necesita recodarea sau readaptari specifice, documenteaza-te la fiecare. 8. Documenteaza-te Multa bafta ! O sa ai nevoie... Eu am avut bafta :-)
